Good morning everyone. I am new to this forum after lurking for a few months. Finally registered and hope to participate in the vast knowledge contained here!
I'm a DIY mechanic, as I have virtually no trust for shop mechanics (other than a good machine shop near me) and feel I can do a better job on my own.
That said, a few weeks back I decided to change the timing belt on my 1993 Corotlla DX, 203,000 miles, 4 speed auto. I've changed timing belts before, so this wasn't such a big deal. When I was finished, the engine vibrated extensively which had me very concerned. However I had foolishly powerwashed the engine prior to starting it, and I suspect moisture had caused this. After a few days the vibration dissipated, and is very slight now. I have not owned the car very long, so I simply can't remember whether there was a slight vibration prior to the job. From what I read here, this is normal so I've learned to live with it.
Never-the-less, my impetuous nature got the better of me, and I decided to pull the valve cover off to see if the cam timing marks lined up properly when the crank was at 0 (zero) degrees. I took two pictures for better illustration:
From the side:
From the top:
As you can tell from the side picture, the cam mark is virtually dead on. However, it appears a bit left of center. It is not so obvious from the top view
If I move the crank shaft so the cam timing mark is more center (which is a literally a millimeter of movement towards the right), the crank advances a few degrees from zero.
In any case, my big concern and question is whether the pics fall within the realm of acceptability? Could I be undermining the integrity of the engine? I was sure that it was lined up when I did the job...but at tight angles its kinda tough to see straight on. Any thoughts on this issue are welcome!
