Seat Belt issue on Corolla 97 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-11-2006, 09:21 AM   #1 (permalink)
View anorbert's Photo Gallery
Canada Seat Belt issue on Corolla 97
Guys need help.
My driver side seat belt is locked and I am unable to wear it. Sometimes a few tugs help it release from the locked mode.
I have had my seat belt replaced in Jan 03 and the problem is back again.
Any thoughts on why this is happening ?
Please let me know.
Cheers Guys.
Anton.
anorbert is offline   Reply With Quote
Old 10-11-2006, 09:35 AM   #2 (permalink)
View SlyckTom's Photo Gallery
There are a few reasons for this. I have a 93, and the belt used to drag very slowly back into its housing.
If your belt is completely locked up, the spring that holds the locking mechanism has either come loose or has broken. There's also a pull mechanism in there that sometimes fails. This mechanism works on the stopping force of your car, and locks the belt. You will need to pull off the interior plastic that covers the locking mechanism. This is located between the front and rear doors near the floor. The innards are a bit complex...but since your belt is already useless you have little to loose.
From there, several reasons exist why your belt has locked up. With some mechanical knowledge and patience (and perhaps some WD-40), you will probably figure it out.
If there's no easy fix to the situation, I would suggest heading to your local junk yard and finding belt housing mechanism that is in good working order. May also be the safer option.
SlyckTom is offline   Reply With Quote
Old 10-11-2006, 03:36 PM   #3 (permalink)
Canada Seat Belt.
Thank you Tom.
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Seat belt rattle cause found - what to do now? MikeX 2nd Generation (2005+) 26 05-05-2006 08:23 PM
seat belt got stuck in... simplyxtrippin Camry & Solara Lounge 2 04-06-2006 05:53 PM
Seat Belt Fix Also Works On Lexus IS350 BJM711 General Lexus Discussion 0 01-21-2006 05:26 PM
'97 Geo Prizm same engine as a '97 Corolla? jbattenhouse Archived Corolla threads 5 12-07-2004 11:50 AM
