HELP 20v problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-11-2006, 11:39 PM   #1 (permalink)
View gasman's Photo Gallery
Unhappy HELP 20v problems
after prtting in a speeds sensor made from 2 magnets connected to the drive shaft and a magnetic reed switch with the ecu side as the ground. when i drive it now theres now power when i add power between 2-4k. was running fine before i put it in.
ive disconnected it and theres still no power when i accelerate briskly between 2-4k.
how do i reset the ecu? i tried leaving it overnight with the power disconnected but didnt work
car is an ae92 with a blacktop 20v in it btw
whats the resistance of the HT lead from coil to dizzy? i was leaning on it pretty hard when i was making my speed sensor and im thinking i make have broken it.
cheers
Brake-Down Shift-Turn
gasman is offline   Reply With Quote
Old 10-12-2006, 12:16 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Are you trying to use the original 20V sensor? Use the mechanical one from the AE92.
Old 10-12-2006, 12:43 AM   #3 (permalink)
my ae92 was carby so didnt have an electronic speed sensor in the dash. i got the mechanical cable running from the gear box to dash and i got some magnets stuck on the drive shaft and a switch that ticks on when the magnets swing by which is connected to the ecu.
Old 10-12-2006, 07:37 AM   #4 (permalink)
KDM is in
REN69's Avatar
I don't recall seeing any AE92s that had electronic sensors, as far as I've seen, they started the electronic sensors with basically anything after 1992 I would assume.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 10-12-2006, 09:44 AM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
yea speedo's in the sr5 and gts were both done by a cable
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 10-12-2006, 03:51 PM   #6 (permalink)
The TN Member
View punter's Photo Gallery
The problems are unrelated. No speed signal to the ECU will trigger a CEL but won't actually do anything.
I disconnect my speedo on track days to avoid the 180 cut-out and the lap times don't change.
The hesitation problem is common on blacktops, what is you timing set to?, it is probably either detonation or a faulty knock sensor.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 10-12-2006, 06:08 PM   #7 (permalink)
Nordschleife racer
Michel H's Avatar
View Michel H's Photo Gallery
Yeah and check your lambda and see if all 4 wires are ok. I had same problem with my BT and turned out the lambda was broky. Yay.
Michel H is offline   Reply With Quote
Old 10-14-2006, 02:54 AM   #8 (permalink)
ive fixed it now, seems that i wired it in backwards. even tho with the speed sensor it doesnt seem to rev higher
Old 10-14-2006, 08:08 AM   #9 (permalink)
View micro214_kp61's Photo Gallery
where does it rev cut?
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 10-15-2006, 05:12 AM   #10 (permalink)
The TN Member
mine is 8400, which is the facelift ECU, prefacelift should be 8200.
If not wired correctly they seem to cut at about 7600.
F/S : 20V ST/BT wiring Service kpsxtyone Car Parts for Sale 15 03-15-2010 08:57 AM
20V Swap, can someone help? -HiTMaN- Archived Corolla threads 8 02-24-2006 05:02 PM
20v ITBS to 16v, or 20v Swap canadianae92 Archived Corolla threads 32 12-30-2005 09:25 AM
Power Door Lock/Window Problems digger1978 Camry & Solara Lounge 4 06-28-2005 02:44 PM
