Cone Filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-12-2006, 02:52 AM   #1 (permalink)
SLIP's Avatar
View SLIP's Photo Gallery
Cone Filter
Hallo peeps...
I just need some advice.
I want to change my air box with a cone filter.
But there is a small thingy that plugs into my air box....
My friend sez its a "Air Flow Meter"....
Does any one know what the purpose of the AFM is..?
And can I drill a hole on the metal Pipe of the Cone filter and plug it in there..?
SLIP is offline   Reply With Quote
Old 10-12-2006, 06:54 AM   #2 (permalink)
View RogerUKAUS's Photo Gallery
Why would you want a cone filter? What is wrong with the original fitment?
Roger
RogerUKAUS is offline   Reply With Quote
Old 10-12-2006, 07:01 AM   #3 (permalink)
SLIP's Avatar
The cone gives a better sound...., and sometimes a slight performance increase....
Old 10-12-2006, 07:07 AM   #4 (permalink)
View SlyckTom's Photo Gallery
Behold the definition according to Wikipedia: http://en.wikipedia.org/wiki/Air_flow_meter
Check with the manufacturer to see if the cone type replacement has an insert for the AFM. Most do, but I'd look into it just in case...
Apparently they are more efficient in the delivery of air into the intake. Better efficiency equals more horsepower and better fuel economy. That and they look kinda cool.
SlyckTom is offline   Reply With Quote
Old 10-12-2006, 07:29 AM   #5 (permalink)
SLIP's Avatar
Cool I will chat to my suppliers and ask them if they have a filter were n' can input the AFM....
Thanks SlyckTom for the help... ;-)
Old 10-12-2006, 07:31 AM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
The name says it all "AIR FLOW METER" it measures the flow of air for the ECU to calculate the fuel/air ratios, and yes you still need it unless you convert your motor to a MAP (Mass Air Pressure) based ECU and sensors.
If you want to put a cone filter, just get a Toyota AFM adaptor, btw what motor do you have?
Old 10-12-2006, 07:46 AM   #7 (permalink)
SLIP's Avatar
I have a 2000 16i toyota corolla....
I think getting the adaptor would be a good idea....
Old 10-12-2006, 08:00 AM   #8 (permalink)
KDM is in
REN69's Avatar
Motor.. not model, 4AGE, 4AFE, etc.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 10-12-2006, 08:05 AM   #9 (permalink)
SLIP's Avatar
hmmmm.....
Give me a bit and ill go check...
Old 10-12-2006, 08:11 AM   #10 (permalink)
SLIP's Avatar
It's a 4A-FE
Old 10-12-2006, 09:35 PM   #11 (permalink)
4AFESPEED
TheOtherCarolla's Avatar
View TheOtherCarolla's Photo Gallery
The "crimp bent: intake tubing with noise supressors is the biggest intake restriction after the filter. The filter may even give you less hp since its sucking up hot underhood air. I say get a full cold air intake or just slap a K&N in there.
93' Prizm - Friend wrecked it R.I.P. 10-19-07
89' 240sx - Now daily driver, rb20 swap
FMIC, 11psi, 3in exhaust..
TheOtherCarolla is offline   Reply With Quote
Old 10-13-2006, 12:02 AM   #12 (permalink)
SLIP's Avatar
This is the filter I have in mind....
Old 10-13-2006, 07:21 AM   #13 (permalink)
KDM is in
REN69's Avatar
I don't recall if the 4AFE had an AFM but I could be wrong.. take a pic of your motor and we'll be able to tell you if you need it or not, as far as I know, the few 4AFEs I've seen didn't have AFMs.
Old 10-13-2006, 07:35 AM   #14 (permalink)
SLIP's Avatar
Will do.... ;-)
I spoke to some other guys and they say it's a "air temperature meter"
It's a little plug that connects onto the front, top half of the air box....
Old 10-13-2006, 07:37 AM   #15 (permalink)
SLIP's Avatar
And will a K&N Flat pad filter increase performance or change the engine sound..?
Longevity of Synthetic oils? Blackhawk3D 3rd & 4th Generation (1992–1996 & 1997–2001) 20 11-24-2006 11:59 PM
Sure was fun changing my oil today... Infinitrium Archived Corolla threads 18 10-12-2006 08:38 PM
Adding Performace Cone Filter to Tercel yaitisme Tercel, Paseo, Starlet, and Sera Forum 3 11-19-2005 02:08 PM
CAUTION to anyone using a funnel cone type filter wontonjohnny General Discussion 7 04-26-2004 12:25 PM
How to install Cone filter on gen 2 V6? Gen2RacerX 1st & 2nd Generation (1983–1986 & 1987-1991) 1 09-04-2003 09:04 AM
