might be getting another GTS :) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2006, 04:32 PM   #1 (permalink)
Sexy Run
AE92_GTS88's Avatar
View AE92_GTS88's Photo Gallery
I might get another corolla gts for dirt cheap but there is a problem. The guy told me there is a broken sensor in which the engine is not getting any spark. What could this be? Should I even bother to get the car?
jDm tOIt AIIIIGHT!
Jesus I suck . I apologize for this.
AE92_GTS88 is offline   Reply With Quote
Old 10-14-2006, 11:39 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
The ignitor maybe, who knows.
Old 10-15-2006, 11:00 AM   #3 (permalink)
CCC-norchap
sportrally88's Avatar
View sportrally88's Photo Gallery
i maybe getting a gts aswell .....he says it doesnt always start but when it does it runs great!....i wonder what it is....maybe the starter getting stuck
sportrally88 is offline   Reply With Quote
Old 10-15-2006, 01:30 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
the connector on the start is corroded maybe? that would cause it not to start sometimes..
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 10-15-2006, 03:09 PM   #5 (permalink)
Sexy Run
AE92_GTS88's Avatar
hey thats pretty odd the guy im buying it from said the same thing...
jDm tOIt AIIIIGHT!
Old 10-15-2006, 04:31 PM   #6 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Even if it doesnt start/run right away, and you can pick it up for a decent price, you wont lose anything. There arent that many things to investigate for the car to engage the starter. How much is the asking price for it?
1. The ignition switch/wiring
2. The starter connections
3. The battery connection to the starter
4. The starter itself
diver9000 is offline   Reply With Quote
Old 10-15-2006, 04:54 PM   #7 (permalink)
CCC-norchap
$250 for mine
Old 10-15-2006, 06:59 PM   #8 (permalink)
Sexy Run
AE92_GTS88's Avatar
mine is a 1991 GTS with 160,000 miles for $300 U.S, btw sport rally what color is the one you're getting? Im geting black.
jDm tOIt AIIIIGHT!
Old 10-15-2006, 09:46 PM   #9 (permalink)
CCC-norchap
grey here!
Old 10-16-2006, 06:31 PM   #10 (permalink)
Gameroom cash: $121755
ok.....
if the owner of the car says "it won't run, it needs a sensor, it doesn't get spark".... then it's the ignitor.....
BUT if the car every now and then *does* start... it is NOT the ignitor..... probably just a bad coil (or even coil wire.... my ae92 eats coilwires..... it's been through 1 set of spark plug wires and 4 coilwires)
if the engine just doesn't crank over... first thing i would try is checking the grounds... the easiest way to do this is to use a jumper cable.... run from the negative to somewhere on the block near the starter.... if it starts, then replace some ground wires (and maybe add one or two).... had this problem in one of my mr2's (replaced starter after starter... only to find out it was ground issues)
1) 1990 Corolla "SR5", part silvia, 7age.... & more 2) 1986 MR2, "MK1.22" 91 5SFE/S54 swap 3) 2010 Corolla S 5-speed (the super nice/low mileage DD - wife) 4) 1998 Camry (the boring, high mileage DD - me)
Old 10-16-2006, 07:19 PM   #11 (permalink)
diver9000's Avatar
Braided steel works great for engine grounds.
FS: 1986 GTS Corolla w/blacktop vvloolvv Vehicles 8 02-03-2009 09:48 PM
AE86 GTS to SR5 same as AE92 GTS to SR5 Conversion? OwnerOfReality Archived Corolla threads 34 08-02-2006 05:37 AM
tC or Toyota Celica! switchex 1st Generation (2005-2010) 21 05-06-2006 09:22 PM
GTS rear end into SR5...help needed etxxz Hardcore Tech and Competition 1 09-09-2005 12:56 PM
Celica Gts or Corolla Gts Den Celica Forum 14 09-12-2002 03:51 PM
