brake lights always on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2006, 03:34 PM   #1 (permalink)
View littlledevil696's Photo Gallery
i seem to have an issue with my 1994 corolla. the brake lights are always on if the headlights are on and if the headlights are off then when i hit the brakes the guages light up as if the headlights were turned on. i'm not quite sure where to begin to diagnose this problem. if anyone could help me that would be great. thank you.
littlledevil696 is offline   Reply With Quote
Old 10-15-2006, 04:52 PM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
Brake light switch, that the brake pedal arm hits, probably has gone bad..
if you can get and afford the factory switch get that one, if you can't get the factory replacement, grab one from autozone or your local auto parts store..
retiredat44 is offline   Reply With Quote
Old 10-15-2006, 08:20 PM   #3 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
View Kr0n1k's Photo Gallery
Check your fuses! This happened to me in my old Sentra, was just a couple of blown fuses.
Kr0n1k is offline   Reply With Quote
Old 10-15-2006, 09:05 PM   #4 (permalink)
Exclamation
You should be so lucky if it's only a fuse
Old 10-15-2006, 09:30 PM   #5 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Dealer price- at least $60.00 Auto Parts Store- $12.00 You do the math.
If it is the BLS make sure you check the little rubber boot that the switch presses against. Sometimes that rubber boot can wear out and the switch could still be ok.
diver9000 is offline   Reply With Quote
Old 10-15-2006, 09:48 PM   #6 (permalink)
View Mayur's Photo Gallery
My dads switch went bad on our ES300. The lights wouldnt turn on at all. Not exactly sure how much it cost but I did know that he was also blowing fuses. We got that fixed and the lights still didnt work and sourced problem to the switch.
Mayur is offline   Reply With Quote
Old 10-16-2006, 07:43 PM   #7 (permalink)
well i checked all of those things and they all seemed to be fine. i removed my amp and subs to sell them to a friend and for some reason that fixed the problem. if someone knows maybe why this happened i'd be curious to find out. thanks for eveyrones help.
Old 10-16-2006, 08:16 PM   #8 (permalink)
View 94_Rolla_Guy's Photo Gallery
Check the brake light bulbs in the taillights what can happen is the filaments fuse togeather and back feed the opposing circuit ie regular lighting. I would start there, also may want to add some di-electric grease to sockets to prevent corrosion which seems to be a problem
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 10-16-2006, 09:44 PM   #9 (permalink)
diver9000's Avatar
Sounds like an overloaded circuit.
Old 10-16-2006, 11:01 PM   #10 (permalink)
Bitter's Avatar
Gameroom cash: $486150
View Bitter's Photo Gallery
sounds to me like the amps ground was backfeeding voltage into the tail lights.
Bitter is online now   Reply With Quote
Brake Lights Wolfcastle Archived Corolla threads 14 08-17-2006 12:55 AM
Charge AND Brake Lights on-HELP! Longstreet Pre-88 Toyota Pickup/Hilux 14 08-14-2006 12:40 AM
Brake lights staying on.... RA24_4_Me Archived Corolla threads 6 08-07-2006 12:54 PM
brake lights. hellomota Camry & Solara Lounge 4 07-23-2006 12:25 AM
Ford brake conspiracy EKam Hardcore Tech and Competition 19 04-02-2004 08:17 PM
