1993 Ecu - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2006, 01:10 AM   #1 (permalink)
View goooopher's Photo Gallery
1993 Ecu
Hey does anyone know where the ecu is located in a 1993 corolla 4A-FE 1.6L?
goooopher is offline   Reply With Quote
Old 10-17-2006, 01:28 AM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
its burried in behind the heater controls and the cigarrette lighter on the hump of the tunnel up against the firewall, not fun to get to
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 10-17-2006, 11:50 AM   #3 (permalink)
thanks, have you done anything with it? like do you know first hand if its something that needs the entire dash taken off to get to it?
Old 10-18-2006, 01:33 AM   #4 (permalink)
View silkydraws's Photo Gallery
no just the lower console under the dash. may help to start at shifter console and work up to it. I know there are 2 phillips head screws that require just using a bit like in a power screwdriver or a offset screwdriver (90 degrees) because of the close clearance. You sure you got a puter prob.? It's not that common (compared to American cars of the 80s early 90s)
silkydraws is offline   Reply With Quote
Old 10-19-2006, 12:27 AM   #5 (permalink)
no i dont have a problem i am just looking to get an aftermarket ecu or JET chip bc im putting in perf fuel injectors and all the sites that i look at say that in order for high perf injectors to work to their max ability they need a new or newly programed ecu to create new fuel to air ratios and settings
4AGE ECU Reset & Teach REN69 Archived Corolla threads 24 10-28-2011 05:58 AM
The Free Mod Series - Part IV Cheaply Monitoring the ECU & A/F Toysrme Camry & Solara Lounge 10 08-16-2009 10:54 PM
Asap!! Haynes Book Bites-need Schem.of 91`22re Ecu Wire`n Diagram-2 Plug Ecu Not 3 charrliy525 Pre-88 Toyota Pickup/Hilux 0 05-19-2006 11:53 PM
