1991 corolla problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2006, 11:03 PM   #1 (permalink)
View tysn's Photo Gallery
i recently bought a 91 corolla for 100 bucks. had to fix a few things on it but it runs great, what oil weight should i use in it meaning it get cold here in idaho and it has 205k miles? anyways, my fuelguage doesn't work. i filled the tank and the guage is below E. how could i go about fixing this? also my cruise control works fine during day driving, but if i turn on the headlights i can get the light to light up on the cruise but it fails to work, any ideas on how to troubleshoot this? thanks guys.
tysn is offline   Reply With Quote
Old 10-17-2006, 11:19 PM   #2 (permalink)
Infinitrium's Avatar
View Infinitrium's Photo Gallery
Well, for the oil I'd run a 5w30. I've got an 88 Corolla and I'm running a 5w30 high mileage oil, might be worth considering in your case. As for your fuel gauge, does your low fuel light work? If the low fuel light works but the gauge itself doesn't then I suspect a problem with the gauge, otherwise it's probably a sending unit problem. The cruise control problem I have no idea about.
Infinitrium is offline   Reply With Quote
Old 10-18-2006, 12:29 AM   #3 (permalink)
View silkydraws's Photo Gallery
Rare to even find a Rolla with CC. If I ever get hold of one I may keep it. I hate long drives w/o. Fuse? Cable ? check around the simple things. In 91 they did'nt run off VSS? Since I hav'nt seen one I dunno but check the wiring (from a book or this site) and see how it's activated and gets a reading.
silkydraws is offline   Reply With Quote
Old 10-18-2006, 09:42 AM   #4 (permalink)
CCC-norchap
sportrally88's Avatar
View sportrally88's Photo Gallery
i have cruise control .....i know how to fix your problem.....if you look by ur brake pedal at the top you'll see a little button that works the brake lights there should be a little rubber stoper that presses it down....go to the dealer they will know what ur talking about it cost like a 1.80 ....without this CC wont work!
sportrally88 is offline   Reply With Quote
Old 10-18-2006, 03:46 PM   #5 (permalink)
the cruise works so long as i don't turn my lights on. i turn them on and the cruise fails to work. does that brake rubber boot thing have anything to do with the lights? cause other than that it works fine.
Old 10-18-2006, 05:01 PM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
All GTS I've seen seem to have Cruise control. The sedans are always a pick and chose deal.
Old 10-20-2006, 09:14 PM   #7 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
I cant see how the brakes or the brakelight switch, or the rubber boot would have anything to do with the headlights or how the headlights affect your CC. Yeah if you push the brakes, the cruise is suppose to release, but whats all that got to do with the headlights?
diver9000 is offline   Reply With Quote
Old 10-22-2006, 12:02 AM   #8 (permalink)
CCC-norchap
u have another problem ...maybe the magnet is off
07 Corolla vs. 07 Mazda vs. 91 Corolla billsif Archived Corolla threads 12 10-18-2006 02:38 AM
2005 Corolla S Airbag light & Fuel problems 2005corollaS Archived Corolla threads 2 03-29-2006 11:47 AM
starting problems when hot 2000 corolla cee710 Archived Corolla threads 14 04-05-2005 04:42 PM
1999 toyota Corolla LE problems: Seeking Advise rvlalg General Discussion 3 03-27-2005 12:40 PM
1991 Corolla all-trac wagon...!!! TeamTRJ Archived Corolla threads 8 12-04-2004 05:25 PM
