transmission fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2006, 04:43 AM   #1 (permalink)
View knoxtoy87's Photo Gallery
transmission fluid
i have a 89 corolla. i'm wondering if the transmission fluid and differential fluid are different.
knoxtoy87 is offline   Reply With Quote
Old 10-22-2006, 09:48 PM   #2 (permalink)
help..
Old 10-22-2006, 09:56 PM   #3 (permalink)
View toyomoho's Photo Gallery
If an automatic, use the same fluid in the differentials as specified for the trans. Otherwise, use a gear oil such a 75W-90.
Old 10-23-2006, 12:20 AM   #4 (permalink)
its a automatic. is there another fill in plug to the differential?
Old 10-23-2006, 03:59 PM   #5 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Your car is front wheel drive .... right?
diver9000 is offline   Reply With Quote
Old 10-24-2006, 04:15 AM   #6 (permalink)
yeah
Old 10-24-2006, 04:16 AM   #7 (permalink)
yeah
Old 10-24-2006, 11:30 AM   #8 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I always thought on a fwd the diff ran in your tranny meaning it ran in the tranny oil?
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 10-24-2006, 02:03 PM   #9 (permalink)
Not sure if this trans shares the diff and trans fluid. Check around the diff housing for fill and drain plugs. The drain plug could be on the bottom or driver’s side of the differential house. The fill plug could be on the rear of the diff housing between the housing and firewall, or on the drivers side of the housing. If they exist, make sure you find the fill plug and that it can be loosened before removing the diff drain plug.
Old 10-24-2006, 07:06 PM   #10 (permalink)
View 20vstarlet's Photo Gallery
They run the same fluid but are two different systems, completely sealed from each other. A good upgrade is to run gear oil in the diff. I know this because I blew up my 90 trans and had it rebuilt.
20vstarlet is offline   Reply With Quote
Old 10-24-2006, 07:09 PM   #11 (permalink)
The diff fill plug is against the fire wall and mine took a 17mm wrench
Old 10-26-2006, 01:19 AM   #12 (permalink)
what kind of gear oil can i use?
Old 10-26-2006, 01:32 PM   #13 (permalink)
I can't remember what weight I used but it was something towards the lighter end of the scale.
Old 10-26-2006, 01:54 PM   #14 (permalink)
Toyota recommends running in the differential whatever fluid is used in the transmission. If an automatic, this would be Dexron, Type V, etc. If a manual, this would be 75W-90. Automatic transmission fluid is basically a 10-weight oil.
Old 10-27-2006, 07:56 PM   #15 (permalink)
i cant find the plug
DIY flush transmission fluid popeye08 Camry & Solara Lounge 6 07-02-2010 11:10 AM
power steering fluid colour!? wtf 95 COROLLA Archived Corolla threads 14 06-02-2009 10:18 AM
Transmission Fluid Change? James Schmidt 1st Generation (1995-1999) 3 08-10-2006 03:49 PM
Transmission Flush Scare 03ESimposter Camry & Solara Lounge 14 12-07-2004 01:19 AM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
