ABS Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2006, 07:20 PM   #1 (permalink)
View opiezm's Photo Gallery
ABS Light
I have a '94 Corolla with the ABS light on. I have checked the reservoir and it's ok. I have tried unplugging the battery for a bit and it comes back on. It's not worth it to me to get it fixed. Basically I just want the light off (NYS inspection due soon). I didn't see a fuse to disable it. Any suggestions? (black tape isn't an option)
opiezm is offline   Reply With Quote
Old 10-18-2006, 07:48 PM   #2 (permalink)
View Mayur's Photo Gallery
Pull out the cluster and take out the bulb.
Mayur is offline   Reply With Quote
Old 10-19-2006, 02:06 AM   #3 (permalink)
View 94_Rolla_Guy's Photo Gallery
Straight from the 1993 Toyota Service Manual
to reset the code:
the DLC or diagnostic port under the hood
1. theres something called a "short pin" its basically a plastic jumper across two pins opposite the hinge side of the lid, REMOVE it
2. Use a piece of wire and jumper "Tc" to "E1"
3. turn Ignition to "ON"
4. depress brake pedal 8 times or more within 3 secs (doesn't have to be hard)
5. it should show normal code which is: (in sec) 2 off .25on .25off .25on .25off........basically constant fast blinking, if its anything else you have a new fresh code....
6. Remove the jumper wire from "Tc" to "E1"
7. Reinstall "short pin"
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
ABS warning light ON!!!!!!!!! szeyee Archived Corolla threads 2 10-04-2005 01:12 PM
ABS light stays on - 94 Corolla bertherr Archived Corolla threads 2 06-10-2005 07:10 AM
95 SE abs warning light, pls help! c95se 3rd & 4th Generation (1992–1996 & 1997–2001) 9 01-07-2005 12:40 PM
ABS light comes on profuse007 Camry & Solara Lounge 10 08-28-2004 10:22 AM
