Must one take off the dash to do this? I took the dash of my '90 Prizm and I don't see how you could replace the instrument panel lights without doing this. But perhaps someone knows a way to reach up beind there and do it.
If you remove the dash, the first step is to remove the steering wheel, so it helps to have a steering wheel puller. Check that you get a puller with a selection of metric bolts. If you only get non-metric bolts you have no chance of getting some that fit.
The lights around the console near the shifter , on an AT, can be replaced without messing with the dash.
