spark plugs torque specs??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2006, 12:03 PM   #1 (permalink)
View rice's Photo Gallery
greetings, i was in the process of changing my spark plugs and noticed the manual says 150 inch-lbs. I was confused, is there another torque wrench to use? I currently have a torque wrench that says "foot-lbs". Should I go buy a torque wrench thats labeled "inch-lbs"??? I know for sure that I should not torque these spark plugs with the same torque wrench as the one i use for my lug nuts since 80 ft-lbs on my lug nuts are freakin tight already!!! thanks for the help!
rice is offline   Reply With Quote
Old 10-21-2006, 01:02 PM   #2 (permalink)
View OEMonkey's Photo Gallery
Just wrist tight buddy. Do not overtighten, these are threads you absolutely don't want to strip. If you wanna be technical and use a torque wrench, then 150" lbs. = 12.5' lbs. Again, that's 12.5 foot pounds.
OEMonkey is offline   Reply With Quote
Old 10-21-2006, 01:24 PM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
finger tight, then 1/4 turn is how i do new plugs. that crushes the steel washer into place well, however i do this with a COLD engine. on a warm/hot engine i use finger tight and 1/8th turn then i'll recheck them later and snug them down a little more if needed. reason being, hot aluminum is ALOT softer than cold aluminum.
Old 10-21-2006, 03:27 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
yea I also do it by hand, shop I worked at it did it that way too. Just do not over tighten, aluminum isn't that hard to mess up :p
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 10-21-2006, 06:58 PM   #5 (permalink)
yeah thanks guys for confirming, I also noticed that it was only nug tight and not real tight
Old 10-21-2006, 07:18 PM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
As long as they're tight enough that you can't losen them up by hand, you should be ok. I usually tighten them a couple of turns and that's it.
Old 10-21-2006, 07:57 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
I thread them by hand with the extention, rather than with the socket wrench so I don't corss thread it
Old 10-23-2006, 01:33 PM   #8 (permalink)
4AFESPEED
TheOtherCarolla's Avatar
View TheOtherCarolla's Photo Gallery
Aluminum heads max 22 ft lbs. I use a ratchet stright up and down with my one hand, spin the ratchet with my other hand with one finger until i can't spin it anymore and it always works fine.
Dont be a jackass and tighten it to all hell and make it hard for someone else to get out later
93' Prizm - Friend wrecked it R.I.P. 10-19-07
89' 240sx - Now daily driver, rb20 swap
FMIC, 11psi, 3in exhaust..
TheOtherCarolla is offline   Reply With Quote
Spark Plugs - How hard can it be? 95t100xcb T-100 7 07-28-2007 07:53 PM
How long do platinum spark plugs last? NewRacer Camry & Solara Lounge 8 05-24-2006 06:52 PM
190,000 km - 1st spark plugs change ToyotaToday Camry & Solara Lounge 8 04-22-2006 11:56 PM
Anyone using Nology Silverstone Spark Plugs TRD_Rob Camry & Solara Lounge 1 03-18-2004 12:28 PM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 09:54 AM
