all o2's are either flanged or screw in..... they are universal.... there are so many different ones available because different car manufacturers use different plugs.... the signal (for all narrow-band o2's) is always 0-1v.... there is generally one feed wire (the 0-1v), sometimes a ground wire, and if it's a heated o2 then there will be 2 wires for the heating circuit....
so, you could go and get a universal o2 if you wanted
