Help Intake Filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2006, 06:42 PM   #1 (permalink)
FF, DRIFTER
View twin88cam's Photo Gallery
AE92 Help Intake Filter
need help on putting an aftermarket filter on my stock piping, what sensors need to saty and what can go on an 88' ae92 corolla gts
88 AE92 GT-S
twin88cam is offline   Reply With Quote
Old 10-25-2006, 10:32 PM   #2 (permalink)
'88ROLLAGTS's Avatar
View '88ROLLAGTS's Photo Gallery
What sensors are in your way of installing the filter??
I got a filter and adapter off ebay for something like $10. It was suposed to install on the end of the mass air flow sensor in place of the stock air filter box. This way I wouldn't even have to relocate any of the sensors or the vaccum deal on the stock tubing. I also planned to get a good Quality filter from K&N and put that on instead of the cheap constructed filter from ebay.
The issue I had with the adapter was that the 4 holes were too close to each other keeping it from mounting. Lukily I worked for a metal shop and had it modified. Basically nothing that I purchased was worth it.
Ive heard that a 1989 MR2 (not too sure of the year just know the '87 will not work) has a adapter that will bolt onto the end of the mass air flow sensor and allow a aftermarket filter to be installed. Im told it looks exactly like the one I got from egay, it just WORKS!!
I guess to answer your exact question... None of the sensors need to go if you keep the stock tubing... that is unless you have a different setup of sensors and stuff than I do.
'88ROLLAGTS is offline   Reply With Quote
Old 10-25-2006, 11:18 PM   #3 (permalink)
FF, DRIFTER
Thumbs up
i just custom fabricated an adapter from some sheet metal and 3 inch piping, tig welded it, tested for vacuum leaks, its fine now, thatks for the help anyways tho
88 AE92 GT-S
Air Intake Filter YYY Camry Camry & Solara Lounge 9 03-31-2006 04:22 PM
LESS MESS Oil Filter Replacement 73sport Camry & Solara Lounge 13 12-02-2005 09:34 PM
intake filter cleaning xrs22 1st Generation (2003-2008) 7 11-11-2004 11:18 PM
Tools to remove 5gen oil filter? 97&02camryleI4 Camry & Solara Lounge 25 06-04-2004 01:22 PM
