VALVE ADJUSTMENT specs? 1981 COROLLA - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2006, 12:13 AM   #1 (permalink)
UNCLE BUCK's Avatar
View UNCLE BUCK's Photo Gallery
4th Generation VALVE ADJUSTMENT specs? 1981 COROLLA
I swear I searched but I failed - 1.8 Liter Pushrod Motor - I recall you are supposed to Retorque Head & Motor is to be Hot - I did it about 5 years ago but can't find the specs for Exhaust & Intake gaps & Head Bolt Torque... thanx in advance!
81 COROLLA SHOEBOX STATION WAGON - AUTO
UNCLE BUCK is offline   Reply With Quote
Old 10-27-2006, 01:06 AM   #2 (permalink)
operation boro thunder
View project trueno's Photo Gallery
Valve clearances for your 3T-C (hot):
Intake.......0.008 in (0.20mm)
Exhaust.....0.013 in (0.33mm)
Head bolt torque:
62-68 ft-lbs
project trueno is offline   Reply With Quote
Old 10-28-2006, 06:49 PM   #3 (permalink)
View Hemi3TC's Photo Gallery
Valves are adjusted when the engine is at normal operating temperature.
Nothing is really in the manual about retorquing the headbolts. But if you do you do it
when the engine is cold. Then the valves will not be adjusted properly. So you have to check the cold valve adjustment.
h3tc
Hemi3TC is offline   Reply With Quote
3vzfe valve adjustment OMNI Camry & Solara Lounge 6 11-19-2005 04:16 AM
Specs for valve lash adjustment? Jamez Yaris, Vitz and Echo Forum 1 09-25-2005 05:22 PM
Opinion wanted on valve adjustment kjd Camry & Solara Lounge 3 04-05-2005 07:38 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
85 corolla 1.6l valve adjustment lesmoney Archived Corolla threads 1 02-17-2004 01:48 PM
