The battery is fairly new and I get good voltage from the battery to the fusebox, to the ECU, and to the dash. I removed the alternator and checked it without the alternator connected, and it did the same thing. It had the same hesitation as before. When its not running the battery puts out about 12.8-13v and when its running it puts out about 14-14.5v, so I know its getting a charge I just dont know if there is a relay somewhere that is burned out. Could a bad brake light switch have anything to do with the amount of voltage running to the headlights? I think so in this case cause they all run off the same circuits from headlight to tailight, however I am at a loss as to what to check now.
