1991 Toyota Corrola - side to side swaying - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2006, 06:56 PM   #1 (permalink)
View mac33's Photo Gallery
Question 1991 Toyota Corrola - side to side swaying
I would appreciate any help on figuring out why my 1991 Corrola sways from side to side when riding on bumpy, uneven roads...its very noticeable when driving on uneven sections of hiways at 60 or more mph. Recently installed 4 new struts and this eliminated the up and down bounce but the side to side motion remains.
Thanks for any advice.
Mac33
mac33 is offline   Reply With Quote
Old 10-28-2006, 10:06 PM   #2 (permalink)
View tashirosgt's Photo Gallery
What parts of the suspension did yo check while you were changing the struts? (Tie rod ends? Ball joint?) Has the alignment been checked and are the tires wearing evenly?
And does swaying mean it tilts out of level from side side but drives straight? Or does it tend to veer off the road unless you steer to correct it?
tashirosgt is offline   Reply With Quote
Old 10-28-2006, 11:10 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Most cars do that, I've driven in a lot of cars that sway like that in funky roads. Usually cars with narrow wheel bases do, wide track cars seem to be less prone to it BUT it still happens to them sometimes.
Old 10-29-2006, 02:51 PM   #4 (permalink)
The TN Member
View punter's Photo Gallery
Yea check alignment, what size tyres/rims are you running.
Could be a number of things.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 10-29-2006, 04:27 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
what size tires do you have? the larger the sidewall usually the more flex there is and that could cause your problem
So could a busted swaybar link (on the rear only for the sr5 and sedan, and front and rear for the gts.)
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 10-30-2006, 08:29 PM   #6 (permalink)
Mac33
Old 10-30-2006, 08:33 PM   #7 (permalink)
THANKS to everyone for your suggestions...I will check the alignment first and see if that solves it.
Old 10-30-2006, 08:52 PM   #8 (permalink)
I don't know whether you replaced the springs when you replaced the struts. But your problem made me wonder about the following situation: Suppose I had a '90's corolla where the front and back springs were reversed when I installed the struts/ Would it drive funny? Or would I even be able to reverse the springs? ---just a random thought, it's probably not related to your situation.
Old 10-30-2006, 10:39 PM   #9 (permalink)
The TN Member
Can't reverse them, the diameters are very different.
Old 10-30-2006, 10:40 PM   #10 (permalink)
The TN Member
Could also be things like control arm bushes, swaybar end links or mounts.
A good shop sould give it a quick check over when they do an alignment.
Faulty starter?... turboyota Pre-88 Toyota Pickup/Hilux 14 01-30-2007 12:48 PM
Starter prob. 0legoat Pre-88 Toyota Pickup/Hilux 2 10-13-2006 07:07 AM
ignition going out? seandnw Pre-88 Toyota Pickup/Hilux 1 10-13-2006 07:05 AM
1985 Turbo Diesel pickup alternator dieseltruck Pre-88 Toyota Pickup/Hilux 2 11-30-2005 09:30 PM
Toyota Hits Record CDNVITZ General Discussion 0 02-06-2004 01:27 AM
