Difference between Timing Belt or Chain on 98 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2006, 10:57 AM   #1 (permalink)
View myrc60's Photo Gallery
USA Difference between Timing Belt or Chain on 98
I've had to change a few timing belts on other cars I've owned and at 81,000 miles, I'm worried about my Corolla. Reading through the forum it appears that a chain not a belt is installed on my car. What is the normal lifetime of said chain? When I called my dealer, the person I spoke with said a chain would be like $900 to change especially when any timing belt I've paid to replace was under $300. I think anything that costs that much to replace on a car is asking too much. What happens if the chain breaks; will it ruin my engine?
myrc60 is offline   Reply With Quote
Old 10-29-2006, 03:05 PM   #2 (permalink)
View stubborn1's Photo Gallery
Timing chains rarely break. You'll replace many more things before it becomes an issue. I wouldn't even think of it unless I had close to 200k miles.
stubborn1 is offline   Reply With Quote
Old 10-29-2006, 06:47 PM   #3 (permalink)
Papa Bear's Avatar
View Papa Bear's Photo Gallery
Excellent question... I have a '98 also with over 100K miles. Let's try something..
Has anyone here changed a timing chain on their Corolla ?? Cost ??
Papa Bear is offline   Reply With Quote
Old 10-29-2006, 07:16 PM   #4 (permalink)
The TN Member
View punter's Photo Gallery
Chains will generally start making noise when they are worn out, if there's no noise then there's no problem.
(This is from experence with nissans which have always had chains, can't see why toyota ones would be different)
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 10-30-2006, 06:31 PM   #5 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
Chains will make noise when they are worn out. Generally they never break ,and if they due its usually do to extreme reving and driver neglegence to find out what that horrid noise coming from the engine is.
P.S. Nissans are a pile of poo-poo (Speaking from expierence)
ghost_ryder35 is offline   Reply With Quote
Old 10-30-2006, 07:57 PM   #6 (permalink)
The TN Member
Maybe the ones you get over there are, but we get some awesome ones.
Skylines, silvias, cimas etc. etc.
Timing belt or chain? eyeguy 5th & 6th Generation (2002-2006 & 2007-2011) 7 10-21-2006 07:29 PM
2001 camry le, timing belt or chain yuan107 3rd & 4th Generation (1992–1996 & 1997–2001) 4 06-23-2006 09:15 AM
Does the '93 4cyl have a timing belt or chain? slbks5 89-95 Toyota Pickup/Hilux 11 11-05-2005 01:50 AM
22R timing chain nightmare rddrgn1 Hardcore Tech and Competition 4 05-07-2005 11:23 AM
Question on 98 camry timing belt phil 3rd & 4th Generation (1992–1996 & 1997–2001) 12 04-19-2005 11:27 AM
