Could this be a problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2006, 05:52 PM   #1 (permalink)
View Gman94's Photo Gallery
Ok I pulled the motor and stuff out of my old car and everything else and I was looking at my new one the other day and I just realized its the 1.8L 7AFE engine and I know you said the trans and stuff would all work with the 1.8L even tho I had the 1.6l, but my question is now is will this be a problem like will the trans still work? also will the computer still work since its a 4AFE computer and my new car is a 7AFE? or will I have to find a 7AFE computer from a manual one?
http://www.cardomain.com/ride/2484831
1995 geo prizm: header, hi flow cat, full stainless steel catback exhaust, Short ram intake, custom functional hood, body kit and converted to manual.
Gman94 is offline   Reply With Quote
Old 10-30-2006, 05:58 PM   #2 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
I have no idea, free bump though
ghost_ryder35 is offline   Reply With Quote
Old 10-30-2006, 06:47 PM   #3 (permalink)
View toyomoho's Photo Gallery
Rockauto lists the same ECU for 7AFE as 4AFE.
Old 10-30-2006, 08:17 PM   #4 (permalink)
The TN Member
View punter's Photo Gallery
I can't really understand what you want to do,
what is the engine/trans combo you want to run??
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 10-30-2006, 08:29 PM   #5 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
I agree with Punter..... what are you ultimately trying to accomplish?
diver9000 is offline   Reply With Quote
Old 10-30-2006, 08:38 PM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
He has a 4AFE and he ended up buying a 7AFE to put in place of the old motor.
Transmission will work, the ECU I'm not sure, if Toyota lists the same ECU for both motors then it will work. Only thing I can see NOT working is if both motors have different sensors, you may need the 7AFE wiring harness if it's different than the 4AFE. I'm sure someone has done it before in here, they just haven't posted yet.
Old 10-31-2006, 12:54 AM   #7 (permalink)
View 94_Rolla_Guy's Photo Gallery
im kinda confused... which motor is going where, i think i remember you saying you bought a chassis and are swapping your good running gear into a donar chassis???
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 10-31-2006, 07:09 AM   #8 (permalink)
ok sorry for any confusion im causing.
I bought a car with a auto 1.8L and realized it was the 7AFE not the 4AFE I want to just do a tranny swap from auto to manual not a complete engine swap I have everything from my old car, but my old car was a 4AFE so I want to know if I can still swap the ECU from my old car into my new one so basically I want to know if my 4AFE ECU will be able to take the place of the ECU for my the 7AFE car?
Old 10-31-2006, 03:00 PM   #9 (permalink)
ok so I was at the junkyard today and I was looking at acouple prizms just in case I do need a 7AFE computer from a manual prizm, but they were auto too, but I noticed it had the plug for the clutch pedal button that makes able to start it when it is pressed in so I was wondering why would I even need to switch the computers? or is there something else that I need to switch the computers for?
but I still need to know if my 4AFE computer will swap right in with the 7AFE computer if I even need to swap them.
Old 10-31-2006, 03:14 PM   #10 (permalink)
The TN Member
Why do you need to change the ECU?
An auto ECU will run a manul no problem, just wire the start inhibitor off.
Old 10-31-2006, 03:20 PM   #11 (permalink)
idk someone told me I should change it over too.
how do I wire the start inhibitor off? and where exactly is that
and I thought maybe I would have to cause my old car that im taking the manual tranny out of was a 1.6l 4AFE engine and my new car that im putting that manual tranny into is a 1.8L 7AFE, so I thought I would also have to swap the ECUs, but wasnt sure if my 4AFE ECU would work in the place of the 7AFE ECU.
New car:
Auto 1.8L 7AFE
Old car:
Manual 1.6L 4AFE
Electric problem! Please help!! 1987SR5 Pre-88 Toyota Pickup/Hilux 2 12-02-2005 09:58 AM
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 10:27 AM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
