silver top part numbers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2006, 11:54 PM   #1 (permalink)
View 91gtssilvertop's Photo Gallery
Question silver top part numbers
hi every one. I have a 91 gts. Just pulled the engine/tranny and everything else attached to it. i have a 20V silvertop w/tranny harness, ecu waiting for me to install. I need to know some part numbers for this setup to make my allready hectic life a little less stressfull.
First of all the ECU i have may be wrong. First thing that gives this away is the big sticker that says 4A-GZ on it. Along with the part numbers 89664-12790 and 175700-3373.
If this truly is not right and any one knows the proper part # that i should have, can I please know it too.
Another problem I may be forseeing is the Axle shafts. AE92 did not use a steady bearing on the right axle where as my new silvertop does. Can I just use my old axles with out the bearing?
And lastly does anybody have a parts list of oe #'s for everything else under the hood, ie. timingbelt, waterpump, hoses, throttle cable, cluth parts ect.
91gtssilvertop is offline   Reply With Quote
Old 10-30-2006, 11:54 PM   #2 (permalink)
Thanks Ren.
Old 10-31-2006, 10:14 AM   #3 (permalink)
View micro214_kp61's Photo Gallery
4AGE 20v Silvertop
89661-12770 (M/T)
4AGE 20v Silvertop
89661-12781 (A/T)
BTW, it should only sa 4A-G M/T or 4A-G A/T. no "Z" for 20V
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 10-31-2006, 03:22 PM   #4 (permalink)
The TN Member
View punter's Photo Gallery
If this truly is not right and any one knows the proper part # that i should have, can I please know it too..
Sounds like a GZE ECU, should be able to sell it and make some money. I'll have a look at the number on my 20v ECUs on the weekend if you want.
All axels are interchangable so use what ever you want. But with out the equal length drive shafts (20v setup) you will get torque steer.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 10-31-2006, 03:25 PM   #5 (permalink)
Thanks Ren for merging the threads.
Old 11-01-2006, 01:45 AM   #6 (permalink)
4A-GZE
KnightX_AE86's Avatar
View KnightX_AE86's Photo Gallery
haha i knew mike would pull thur.. =P
KnightX_AE86 is offline   Reply With Quote
Old 11-01-2006, 08:14 AM   #7 (permalink)
i dunno why, i don't even own a 20V anymore!
Old 11-01-2006, 08:15 AM   #8 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Mike, what about 12771 or 12772s?? I think I have a 12772 at home that is supposed to be a Silvertop ECU.
Old 11-01-2006, 09:22 PM   #9 (permalink)
Thanks Ren. first post and I screwed up. Anyways thanks for the replies. Bought the setup on e-bay so i'll try to get them to send the right one first. is there any markings on the engine itself so I know what year it is? The e-bay add just said 92-96. As for the axles, are the equall length ones the same part #? I'm hopefully going to try to get it sitting on the mounts this weekend if time permits, but first i want to put a new t-belt, w/p on it first and check the condition of the clutch. i should be able to get any needed part #'s off the old peices.
Old 11-01-2006, 09:37 PM   #10 (permalink)
The TN Member
What are the throttle linkages like (1 post or 2) andwas it manual or auto.
That will see if it was facelift or not. 90.5 - 93.5 or 93.5 - 95
Old 11-02-2006, 09:11 AM   #11 (permalink)
the 12772 is FAKE.. you got ripped.. hahahahaha!
just joking REN. i just posted some numbers i've come across. from what i remember this is the important part 89661-127XX and don't have a "Z" designation on the sticker, hehehe.
Old 11-02-2006, 09:16 AM   #12 (permalink)
i don't think you'll know the exact manufacturing year. you can only go by what punter said. STs have 2 versions. one with 2 shift linkage posts and the other just 1. that's one of the only ways you can see the difference between the 2.
Old 11-02-2006, 02:42 PM   #13 (permalink)
4A-GZE
WHAT?!?!?! wheres ur starlet?!?!?!?!?
Old 11-02-2006, 05:30 PM   #14 (permalink)
KDM is in
REN69's Avatar
Sold man!! where you been the last 2 weeks??
Mikey, I almost feel like coming over your place and.. hehehe.. good one.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 11-02-2006, 07:56 PM   #15 (permalink)
Nordschleife racer
Michel H's Avatar
View Michel H's Photo Gallery
AE101 20v / GZE :
04111-16201 GASKET KIT, ENGINE OVERHAUL 01.06.1991-01.08.1994 4AGZE..AE101
0411116202
04111-16210 GASKET KIT, ENGINE OVERHAUL 01.06.1991-01.08.1994 4AGE..AE101
04112-16200 GASKET KIT, ENGINE VALVE GRIND 01.06.1991-01.05.1995 4AGZE..AE101
04112-16210 GASKET KIT, ENGINE VALVE GRIND 01.06.1991-01.05.1995 4AGE..AE101
90311-70007 SEAL, ENGINE REAR OIL 01.06.1991-01.05.1995 4AGZE..AE101
90311-70007 SEAL, ENGINE REAR OIL 01.06.1991-01.08.1998 4AFE,4AGE,5AFE..AE10#
11383-15011 GASKET, ENGINE REAR OIL SEAL RETAINER 01.06.1991-01.05.1992 4AFE,4AG#,5AFE..AE10# *KIT*
15100-19036 PUMP ASSY, OIL 01.06.1991-01.05.1995 4AG#..AE101
11291-16050 PLATE, ENGINE NAME 01.06.1991-01.05.1995 4AGZE..AE101 *4agze sticker for boot*
16100-19115 PUMP ASSY, WATER 01.06.1991-01.05.1995 4AGZE..AE101
16100-19245 PUMP ASSY, WATER 01.06.1991-01.05.1995 4AGE..AE101
17670-16010 VALVE ASSY, AIR BY-PASS 01.06.1991-01.05.1995 4AGZE..AE101
13011-16210 RING SET, PISTON 01.06.1991-01.05.1995 4AGZE..AE101;STD
13011-16230 RING SET, PISTON 01.06.1991-01.05.1995 4AGE..AE101;STD
13013-16210 RING SET, PISTON 01.06.1991-01.05.1995 4AGZE..AE101;O/S 0.50
13013-16230 RING SET, PISTON 01.06.1991-01.05.1995 4AGE..AE101;O/S 0.50
13101-16131-01 PISTON SUB-ASSY, W/PIN 01.06.1991-01.05.1995 4AGZE..AE101;STD,MARK 1
13101-16131-02 PISTON SUB-ASSY, W/PIN 01.06.1991-01.05.1995 4AGZE..AE101;STD,MARK 2
13101-16131-03 PISTON SUB-ASSY, W/PIN 01.06.1991-01.05.1995 4AGZE..AE101;STD,MARK 3
13101-16140-01 PISTON SUB-ASSY, W/PIN 01.06.1991-01.05.1995 4AGE..AE101;STD,MARK 1
13101-16140-02 PISTON SUB-ASSY, W/PIN 01.06.1991-01.05.1995 4AGE..AE101;STD,MARK 2
13101-16140-03 PISTON SUB-ASSY, W/PIN 01.06.1991-01.05.1995 4AGE..AE101;STD,MARK 3
13103-16131 PISTON SUB-ASSY, W/PIN 01.06.1991-01.05.1995 4AGZE..AE101;O/S 0.50
13103-16140 PISTON SUB-ASSY, W/PIN 01.06.1991-01.05.1995 4AGE..AE101;O/S 0.50
13401-16020 CRANKSHAFT 01.06.1991-01.08.1998 4AG#..AE101
13201-19126 ROD SUB-ASSY, CONNECTING 01.10.1991-01.05.1995 4AG#..AE101
90105-10076 BOLT, FLYWHEEL SET 01.06.1991-01.08.1998 4AG#..AE101..MTM
90119-12127 BOLT (FOR CRANKSHAFT PULLEY SET) 01.06.1991-01.08.1998 4AG#..AE101
90280-05005 KEY (FOR CRANKSHAFT TIMING GEAR) 01.07.1991-01.08.1998 4AFE,4AG#,5AFE..AE10#
11011-15010 WASHER SET, CRANKSHAFT THRUST 01.06.1991-01.12.1997 4AFE,4AG#,5AFE..AE10#;STD
11011-15020
11704-16010 BEARING SET, CRANKSHAFT 01.06.1991-01.08.1998 4AFE,4AG#,5AFE..AE10#;U/S 0.25
11701-16010-01 BEARING, CRANKSHAFT 01.06.1991-01.08.1998 4AFE,4AG#,5AFE..AE10#;MARK 1
11701-16010-02 BEARING, CRANKSHAFT 01.06.1991-01.08.1998 4AFE,4AG#,5AFE..AE10#;MARK 2
11701-16010-03 BEARING, CRANKSHAFT 01.06.1991-01.08.1998 4AFE,4AG#,5AFE..AE10#;MARK 3
11701-16010-04 BEARING, CRANKSHAFT 01.06.1991-01.08.1998 4AFE,4AG#,5AFE..AE10#;MARK 4
11701-16010-05 BEARING, CRANKSHAFT 01.06.1991-01.08.1998 4AFE,4AG#,5AFE..AE10#;MARK 5
13041-16070-01 BEARING, CONNECTING ROD 01.06.1991-01.08.1992 4AG#..AE101;MARK 1
130411607101
13041-16070-02 BEARING, CONNECTING ROD 01.06.1991-01.08.1992 4AG#..AE101;MARK 2
130411607102
13041-16070-03 BEARING, CONNECTING ROD 01.06.1991-01.08.1992 4AG#..AE101;MARK 3
130411607103
90999-73111 BUSH (FOR CONNECTING ROD SMALL END) 01.06.1991-01.08.1998 4AG#..AE101
13204-16070 BEARING SET, CONNECTING ROD 01.06.1991-01.08.1992 4AG#..AE101;U/S 0.25
1320416071
13265-16030 BOLT, CONNECTING ROD 01.06.1991-01.08.1998 4AG#..AE101
90179-09008 NUT, HEXAGON (FOR CONNECTING ROD BOLT) 01.06.1991-01.08.1998 4AFE,4AG#,5AFE..AE10#
13405-16030 FLYWHEEL SUB-ASSY 01.06.1991-01.05.1995 4AGE..AE101..MTM
13405-16051 FLYWHEEL SUB-ASSY 01.06.1991-01.05.1995 4AGZE..AE101
90916-02179 BELT, V (FOR VANE PUMP) 01.06.1991-01.05.1993 AE101..GTZ
90916-02173 BELT, V (FOR ALTERNATOR) 01.06.1991-01.05.1995 4AGZE..AE101
90916-02232 BELT, V (FOR FAN AND ALTERNATOR) 01.06.1991-01.05.1995 4AGZE..AE101
99365-21050 BELT, V (COOLER COMPRESSOR TO CRANKSHAFT PULLEY), NO.1 01.06.1991-01.05.1993 AE101..G,GT,GTAPX
99365-70840 BELT, V (FOR FAN AND ALTERNATOR) 01.06.1991-01.07.1993 4AGE..AE101
90916-03060 THERMOSTAT 01.06.1991-01.05.1995 4AG#..AE101;*WAX 82-95
28100-16110 STARTER ASSY 01.06.1991-01.05.1995 4AGZE..AE101;12V 1.0KW
28100-16140 STARTER ASSY 01.06.1991-01.05.1995 4AGE..AE101;12V 1.0KW
19300-16011 SENSOR ASSY, CAM POSITION 01.06.1991-01.05.1995 4AGZE..AE101 *CRANK ANGLE SENSOR*
90099-14091 RING, DISTRIBUTOR HOUSING O 01.06.1991-01.10.1994 4AFE,4AG#,5AFE..AE10#
23209-16061-01 INJECTOR ASSY, FUEL 01.06.1991-01.05.1995 4AGZE..AE101;MARK BLUE
23209-16061-02 INJECTOR ASSY, FUEL 01.06.1991-01.05.1995 4AGZE..AE101;MARK BLACK
23209-16061-03 INJECTOR ASSY, FUEL 01.06.1991-01.05.1995 4AGZE..AE101;MARK YELLOW
23209-16061-04 INJECTOR ASSY, FUEL 01.06.1991-01.05.1995 4AGZE..AE101;MARK WHITE
23209-19015 INJECTOR ASSY, FUEL 01.06.1991-01.08.1998 4AGE..AE101
23801-16061 PIPE SUB-ASSY, FUEL, NO.1 01.07.1991-01.05.1995 4AGE..AE101 ***LINE FROM FILTER TO RAIL***
23901-16080 PIPE SUB-ASSY, FUEL, NO.1 01.06.1991-01.05.1995 4AGZE..AE101;NO.2 ***COLD START INJECTOR PIPE***
90923-01377 PIPE SUB-ASSY, FUEL, NO.1 01.06.1991-01.05.1995 4AGZE..AE101;NO.1 ***LINE FROM FILTER TO RAIL***
90923-01380 PIPE SUB-ASSY, FUEL, NO.1 01.06.1991-01.08.1998 4AGE..AE101;NO.2 ***COLD START INJECTOR PIPE***
31470-12092 CYLINDER ASSY, CLUTCH RELEASE 01.06.1991-01.01.1993 AE10#..MTM
3147012093
04313-12030 CYLINDER KIT, CLUTCH RELEASE 01.06.1991-01.01.1993 AE10#..MTM
90311-34017 SEAL, OIL (FOR TRANSMISSION CASE) 01.08.1991-01.08.1998 AE10#..MTM..(F,G,GT,GTAPX,S,SJ,X)
9031134028
90311-50010 SEAL, OIL (FOR TRANSMISSION CASE) 01.06.1991-01.05.1995 AE101..GTZ
9031150027
90311-25011 SEAL, OIL, NO.1 (FOR FRONT TRANSAXLE CASE) 01.06.1991-01.08.1998 AE101..MTM..(G,GT,GTAPX)
90311-30006 SEAL, OIL, NO.1 (FOR FRONT TRANSAXLE CASE) 01.06.1991-01.05.1995 AE101..GTZ
30300-1A030 TRANSAXLE ASSY, MANUAL 01.06.1991-01.05.1995 AE101..GTZ *COMPLETE BOX*
04331-12080 GASKET KIT, TRANSAXLE OVERHAUL (MTM) 01.06.1991-01.04.1997 AE101..(G,GT,GTAPX)..5F
04331-12092 GASKET KIT, TRANSAXLE OVERHAUL (MTM) 01.06.1991-01.05.1995 AE101..GTZ
41301-12180 CASE SUB-ASSY, FRONT DIFFERENTIAL, NO.1 01.06.1991-01.05.1995 AE101..GTZ
33403-19475 GEAR SUB-ASSY, SPEEDOMETER DRIVEN (MTM) 01.06.1991-01.04.1992 AE101..GTZ;N=30,MARK 30:35 elec
31230-20170 BEARING ASSY, CLUTCH RELEASE 01.06.1991-01.05.1995 AE101..GTZ
31210-12170 COVER ASSY, CLUTCH 01.06.1991-01.05.1995 AE101..GTZ
31250-12230 DISC ASSY, CLUTCH 01.06.1991-01.05.1995 AE101..GTZ
3125012231
31236-20060 SUPPORT, RELEASE FORK 01.06.1991-01.05.1995 AE101..GTZ
47730-12420 CYLINDER ASSY, FRONT DISC BRAKE, RH 01.06.1991-01.05.1995 AE101..GTAPX,GTZ **Twin Piston Caliper**
47750-12420 CYLINDER ASSY, FRONT DISC BRAKE, LH 01.06.1991-01.05.1995 AE101..GTAPX,GTZ **Twin Piston Caliper**
43410-12390 SHAFT ASSY, FRONT DRIVE, RH 01.06.1991-01.05.1995 AE101..GTZ
43420-12390 SHAFT ASSY, FRONT DRIVE, LH 01.06.1991-01.05.1995 AE101..GTZ
Michel H is offline   Reply With Quote
Toyota Part Numbers and Ordering snigma General Discussion 2 05-12-2006 08:16 PM
07 Camry V6 part numbers so40 5th & 6th Generation (2002-2006 & 2007-2011) 4 05-08-2006 05:04 PM
Part numbers needed LEGirl Archived Corolla threads 0 12-19-2005 10:57 PM
Part Numbers VVT-i Owns General Discussion 0 06-18-2004 06:40 PM
