Fogged headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2006, 02:31 PM   #1 (permalink)
View sergiomartineng's Photo Gallery
USA Fogged headlights
I own an 04 SE Corolla, my headlights are getting dull in some parts, is this normal after less than three years, is there a way to undull them
sergiomartineng is offline   Reply With Quote
Old 10-31-2006, 03:16 PM   #2 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
04SE I think you mean a 04S...Is it getting dull on the inside or out?....My one light on my 03(same lights) started getting water vapor in it and started to cloud up(condensation) you could even see water drops inside after only one year of owning the car new...was a bad seal..since then I have replaced both lights again for cracks in the glass...A slight clouding in damp/rainy weather is normal but if yours is bad its probably a bad seal or cracked glass..Could also be if you replaced a light bulb recently you didn't fit the bulb back in correctly and is letting in damp air...Its hard to replace the light because to get to the bottom holding bracket you might have to take the bumper off and its a tight fit putting it back in...good luck...
~Radd
Raddman is offline   Reply With Quote
Old 10-31-2006, 03:49 PM   #3 (permalink)
The TN Member
View punter's Photo Gallery
Glass or plastic?
On my levin they are plastic and started to cloud over. A quick polish with brasso and they're good as new.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 10-31-2006, 03:55 PM   #4 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Originally Posted by punter
Glass or plastic?
I was going to suggest he buy some diamond pattern H4 lights with plastic covers and he shouldnt have that problem anymore. The brasso works well too.
diver9000 is offline   Reply With Quote
Old 10-31-2006, 04:21 PM   #5 (permalink)
Registered User
Raddman's Avatar
USA
Glass or plastic?
His headlights are made out of glass...
But never knew brasso worked on plastic headlights, will have to pass that info to my buddy that has a 95 Pontiac with a plastic light bar..We just buffed it out with rubbing compound, took a lot of crud off but still left it hazy..thanks for the tip.
~Radd
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
93 Headlights simms 89-95 Toyota Pickup/Hilux 3 07-03-2006 11:14 PM
Clear Headlights.......Come look! luisitol Camry & Solara Lounge 34 07-02-2005 08:47 AM
fogged up headlights.... bpcamrydude Camry & Solara Lounge 11 08-31-2004 09:55 AM
