Ok, I havent had the time yet to look at the calipers or lift the car to check resistance. but I did touch each wheel and look for smoke. I have found nothing of the sorts. I drive about 45 min every day so my guess is thats enough time to heat things up.
I notice a slight "jerking" motion (for lack of better terms) when coasting out of gear. Is there anything else that could cause this??
As for the clutch I have bled it again with no change.
I guess "feathering" is not a good way to put what I do while on a hill. Its more like letting out the clutch slowly untill I feel it grab then continue to let up. The pedal feels sticky (this is really hard to explain) right at this point. The feeling reminds me of running my finger down a wet piece of glass... when I push harder it makes that squeeky noise and doesnt slide as clean
