engine noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2006, 08:56 AM   #1 (permalink)
View jon_570's Photo Gallery
engine noise
i have a 1997 corolla CE with a 4afe with about 141000 miles on it. one day i was driving and i stopped at a stop light..it was a fairly level road and i heard a noise from the engine and it sounded likethe rocker or car was hitting the valve cover..idk if it was that but thats the easiest way to describe the noise..i reved it probally up to about 2 grand and let it idle again and it still kinda did it. i would say it was ideling about 7-900 RPM then..any ideas as to what it could be?
jon_570 is offline   Reply With Quote
Old 11-02-2006, 09:01 AM   #2 (permalink)
View micro214_kp61's Photo Gallery
did you check your oil?
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 11-02-2006, 09:12 AM   #3 (permalink)
yes im sorry i forgto to add that..thats what i first thought it was and i checked it when i got home on a level spot...it was about 3/4 on the fill line so it was fine...it only does this everyonce in a while..when i stop i turn the radio off and listen and i only hear it about half the time...
Old 11-02-2006, 10:10 AM   #4 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
When the engine makes that noise, is it just a noise, or it there a lot of vibration that goes along with it?
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 11-02-2006, 11:04 AM   #5 (permalink)
it is just a noise..my car doesnt make a whole lot of vibrations unless i have the stereo on
Old 11-02-2006, 01:58 PM   #6 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Cool
Use a mechanic's stethascope.
retiredat44 is offline   Reply With Quote
Old 11-02-2006, 02:47 PM   #7 (permalink)
I asked because that is what my friends car sounded like when one of the motor mounts started to go, but there was a lot of vibration to go along with it. A month later it was constant and could rattle teeth out...
Old 11-03-2006, 12:34 PM   #8 (permalink)
Exclamation
I am not bieng a smartass.. get one, you might be able to use any stethascope, it will help you isolate the noice. Also, don't drive it that way, you might end up making hte problem much worse.. and possibly destroy an engine that need not be detroyed.
Old 11-03-2006, 03:05 PM   #9 (permalink)
wat??dont drive it what way?>??
Old 11-03-2006, 06:03 PM   #10 (permalink)
Exclamation
if the noise is a bearing,, or other serious part, it could really destroy the engine...
but if you think it's nothing serious, drive , drive, drive..
Old 11-03-2006, 06:49 PM   #11 (permalink)
it ONLY happens when at idle and only happens every once in awhile...other wise the motor runs fine..if i blow the motor im getting a 4AGZE
Old 11-03-2006, 08:32 PM   #12 (permalink)
Infinitrium's Avatar
View Infinitrium's Photo Gallery
Ya know, a wooden broom handle would work in a pinch.
Infinitrium is offline   Reply With Quote
Engine Noise 1996 Tacoma 2RZ-FE :( chipsndukes 1st Generation (1995.5–2004) 20 08-21-2010 08:14 PM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 09:38 AM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
my Camry 03 makes loud noise from engine room! poraminna 5th & 6th Generation (2002-2006 & 2007-2011) 6 02-23-2005 09:19 PM
