OPPS..Over Filled Engine Oil..help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2006, 10:10 AM   #1 (permalink)
View jkjk15's Photo Gallery
Canada OPPS..Over Filled Engine Oil..help
I just changed the engine oil for the 03 Corolla and over filled the engine oil. The oil reading is past the maximum.
What are my options here?? Without changing the oil again.
jkjk15 is offline   Reply With Quote
Old 11-02-2006, 10:12 AM   #2 (permalink)
Amber's Avatar
View Amber's Photo Gallery
Loosen the drain bolt and let only as much drain out as needed.
2004 Corolla LE - 5 speed, leather, sunroof, spoiler, fog lights, alloy wheels
600 Mile Club - Founding Member
My FD - 335 hp - ~2800 lbs with me in it!
Amber is offline   Reply With Quote
Old 11-02-2006, 10:47 AM   #3 (permalink)
Papa Bear's Avatar
View Papa Bear's Photo Gallery
How much over full is it ?? If it's just 1/2L or so, I would leave it or do what Amber said.
Keep the "drippings to add later if required.
P.B.
Papa Bear is offline   Reply With Quote
Old 11-02-2006, 04:20 PM   #4 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Get a vampire pump and go through the dipstick tube. Pull out however much you need.
diver9000 is offline   Reply With Quote
Old 11-02-2006, 06:15 PM   #5 (permalink)
Infinitrium's Avatar
View Infinitrium's Photo Gallery
Yeah, a half quart or less is nothing to get worried about. I ran my 88 Corolla that way for 2 weeks because I was too lazy to drain off the excess oil. Nothing bad came from being a half quart over full.
Infinitrium is offline   Reply With Quote
Old 11-02-2006, 10:51 PM   #6 (permalink)
diver9000's Avatar
Hey JK15, how much too full is the engine? If its a small amount, it wont be a problem to leave it alone. Now if its alot too full that can cause you problems.
Old 11-03-2006, 07:59 AM   #7 (permalink)
Its about 1cm above the maximum level...I think from what you guys are saying it should be fine. So I'm gonna leave it. Thanks for the help.
Old 11-03-2006, 09:03 AM   #8 (permalink)
View newbie212's Photo Gallery
Being a toyota mechanic, I wouldn't take a chance on ruining your beloved toyota.. The Maximum mark is there for a reason... It doesnt take much to get under your car and drain the oil into a pan and put that same oil back into the car. Maybe 5-10 minutes.. Yes it might not be a problem but it COULD be.. Its your call and your car but specifications are there for a reason..
newbie212 is offline   Reply With Quote
Old 11-03-2006, 08:11 PM   #9 (permalink)
I really don't think dipsticks are calibrated that accurately that a bit over the full mark would hurt the engine.
Old 11-05-2006, 06:01 PM   #10 (permalink)
'88ROLLAGTS's Avatar
View '88ROLLAGTS's Photo Gallery
Ill go with Newbie212. My sister had a sweet little 88 celica GTS that she over filled about a half QT. Three days later it had a blown head gasket. She did take it on a 150 mile trip but still.
I think it takes like 1QT to make my dipstick move 1CM.
I personally would not risk it. Especially when it sounds as if you had every thing nesessary to do a oil change and this is all you need to simply open it up and let a little out.
'88ROLLAGTS is offline   Reply With Quote
Old 11-05-2006, 06:27 PM   #11 (permalink)
View The Kev Master's Photo Gallery
I found that the service center overfilled my 2005 Camry SE by two quarts, which made the engine feel sluggish. Once I had corrected it, the engine came back to life, which is what happens when you let someone else do your oil change.
The car had about 6 quarts when the recommended amount in the owner's manual is 4.
The Kev Master is offline   Reply With Quote
Old 11-05-2006, 07:14 PM   #12 (permalink)
The TN Member
View punter's Photo Gallery
Unrelated problems.
But still, i'd drain it out, windage is not good.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 11-05-2006, 07:18 PM   #13 (permalink)
I beg to differ. She took this car to Toyota and was told that too much oil was creating too much oil pressure. Come to think of it thats what happened to my buddies truck too
Old 11-05-2006, 07:28 PM   #14 (permalink)
The TN Member
Windage lowers the oil pressure.
and there is no such thing as too much oil pressure, untill you split the oil filter anyway.
Neither of these problem would blow a HG, thats a temperature issue
Old 11-05-2006, 07:29 PM   #15 (permalink)
How could oil pressure blow a headgasket? I could see high oil pressure dislodging a seal or two, but a headgasket?
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 09:38 AM
20R ENGINE REBUILD FROM HELL! (Part Three) nwdetectorist Pre-88 Toyota Pickup/Hilux 1 08-09-2007 07:30 PM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
