parts from ae92 to ae86 swappable? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2003, 03:30 PM   #1 (permalink)
Wheels Direct rep
soulibrium's Avatar
View soulibrium's Photo Gallery
Question parts from ae92 to ae86 swappable?
hey its soulibrium from wheels direct again!
this time i have a question in regards to swappable parts from the ae92 to ae86. any engine parts? mechanical parts? interior parts ? and what not? ive always wondered what can be swapped(well mainly replaced using OEM ae92 stuff, since they are more common then a ae86).
for example: door acuators, seats with slider and bracket, alternator, hoses, rad, electrical lines, brakes, exhaust system, anything !!
thnx for the help !!
cheers, ben
soulibrium is offline   Reply With Quote
Old 05-11-2003, 04:00 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
the engines on the AE86 GTS are pretty much the same as the 88-89 AE92 GTS.. the 90-91 AE92 GTS had a Higher compression engine, so I assume the internals are a bit different (hi-comp pistons, etc). the Hi-comp engine also had no TVIS which means there was no AFM, instead the engine had MAP i think.
Old 05-11-2003, 05:03 PM   #3 (permalink)
TN Track day addict
View Lafora's Photo Gallery
only map sensored hi comp 4AG in north america isn't found on a toyota
it's found on geo prism GSis
My blog
Fast and cheap won't be reliable.
Cheap and reliable won't be fast.
And fast and reliable won't be cheap
Lafora is offline   Reply With Quote
Old 05-12-2003, 03:14 AM   #4 (permalink)
View martiniracing's Photo Gallery
the engine is pretty much the same, except the ae92 comes with a red top high comp (small ports) and a stronger 7 rib block. the intake manifold between the 4age's from ae92 and ae86 are different, since one is horizontal and the other is lateral
seat rails should be different, but i would imagine if you swap the rails between seats, it would be fairly easy
prolly the shift knob is the only thing that is the same on both gts models
steering wheel is not interchangeable between the two models
sell your car free!
www.projectsource.ca
martiniracing is offline   Reply With Quote
Old 05-12-2003, 12:08 PM   #5 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
nope even the smallport has afm. all 4age's on toyotas on our shores come with afm.
everything on the ae92 4age is on the opposite side...so to transfer it over would be a bitch.
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 05-14-2003, 09:19 AM   #6 (permalink)
Wheels Direct rep
soulibrium's Avatar
so in essence, if im looking for some parts i gotta find the orignal parts?!?!!? man, thats really crappy ! for parts in at a dead end then? unless i can find a second ae86 rite?! wow, this is gonna be hard !
thnx for the help guys.
Old 05-14-2003, 11:30 AM   #7 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
what ae86 parts are u looking for????....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
