Failed emmission test-any ideas? (4AGE GTS-16) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2006, 04:58 PM   #1 (permalink)
The High and the Low
View mrdennmann's Photo Gallery
AE92 Failed emmission test-any ideas? (4AGE GTS-16)
hydrocarbons were high, both at idle, and at cruising speed. she's got 220,000 miles on it, but doesn't burn oil. I'm trying to narrow down the repairs, as my tags have expired, and am on a very limited budget.
Does anyone know of anything that would explain the failure? is there some in-expensive options for bringing the emmissions within the pass range?
I made sure it was good and warm, I even temperarily removed the air filter.
Any help would be very appreciated.
mrdennmann is offline   Reply With Quote
Old 11-02-2006, 05:22 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Crap, I can't remember but I think that means your catalytic converter is dead. Don't they tell you guys?? usually here when you go for your E-test and you fail, the mechanic will tell you what the cause is and of course, how much to replace it.
Old 11-02-2006, 06:13 PM   #3 (permalink)
Infinitrium's Avatar
View Infinitrium's Photo Gallery
Maybe you could try some of that emissions cure fuel additive at a parts store or something. Luckily we don't have emissions testing here in this part of Canada. All they check for is to see if the cat is in place. It can be a hollowed out shell, they don't check to see if it actually works. Man if they did bring emissions testing here there would be an awful lot of cars going off to the junkyard.
Infinitrium is offline   Reply With Quote
Old 11-02-2006, 07:22 PM   #4 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Maybe get some injector cleaner, O2 sensor, and have the catalytic converter and collector checked or changed.
diver9000 is offline   Reply With Quote
Old 11-02-2006, 09:02 PM   #5 (permalink)
View 91gtssilvertop's Photo Gallery
how high? post readings and limits.
Could pass with simply retarding the timing a bit.
91gtssilvertop is offline   Reply With Quote
Old 11-03-2006, 12:54 AM   #6 (permalink)
AE92 well.
I think they were off by quite a bit. perhaps double the allowable levels. I know that the spark plugs are pretty old. and maybe it's' due for a cap and rotor. I'd really like to avoid replacing the cat. converter.
I'm going to talk to another Toyota guy that I know. He's familiar with the AE92. I'll see if he's got any suggestions also.
I'll also pick up some of the fuel system cleaner, and try that out.
Old 11-03-2006, 07:58 AM   #7 (permalink)
View goooopher's Photo Gallery
try this...go to a junk yard find a car with a new inspection sticker and peel it off and put it on your car...
goooopher is offline   Reply With Quote
Old 11-03-2006, 09:45 AM   #8 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
check the coolant temp sensor, if thats kaput the engine wont leave warmup mode and will run rich.
Old 11-03-2006, 09:59 AM   #9 (permalink)
If it was running rich you would have high co levels along with the hc. Make sure your ignition parts are all good and your timing is set correctly.
Old 11-03-2006, 12:02 PM   #10 (permalink)
Pow! Right in the Kisser!
Liter's Avatar
View Liter's Photo Gallery
LOL i just got mine done and it passed with flying colours....sucks to be you
Liter is offline   Reply With Quote
Old 11-03-2006, 01:35 PM   #11 (permalink)
AE92 Coolent Temp senser?
I've got no idea where that would be. It makes sense, it runs very rich. so, does anyone have instruction on changing that unit out?
Old 11-03-2006, 02:01 PM   #12 (permalink)
Doctor J's Avatar
Gameroom cash: $263390
View Doctor J's Photo Gallery
I need info on your O2 reading as well as CO.
The common reasons of HC are slightly over limit on EFI Toyota are:
  1. minor intake air leak (lean condition)
  2. bad ignition components
  3. leaking exhaust valves
Doctor J is offline   Reply With Quote
Old 11-03-2006, 02:19 PM   #13 (permalink)
Bitter's Avatar
he didnt mention if his CO was high or not, if its not then i'm wrong.
Old 11-04-2006, 12:55 PM   #14 (permalink)
AE92 O2 levels were acceptable.
so I'm going to attack the Ignition parts. New plugs, cap and rotor. then I'll get it retested.
Thanks for all of your help guys.
Old 11-05-2006, 07:06 PM   #15 (permalink)
View motu 56's Photo Gallery
Most cars will pass with a fresh oil change, air filter change and RXP. RXP is an additive that you read about on the net.
motu 56 is offline   Reply With Quote
K&N: Why take filtercharger over drop-in filter? dELuX-4x4 2nd Generation (2005+) 88 10-02-2007 01:13 AM
Avalon and Impala score best among IIHS side crash test results for large sedans IFCAR Toyota News 1 06-24-2006 05:28 AM
Failed Smog For 90 Celica GTS blackaneseazn Celica Forum 5 06-01-2006 01:42 PM
Yaris failed emissions test androidGB Yaris, Vitz and Echo Forum 12 12-27-2005 12:30 AM
failed emission test nirAE86taba General Discussion 4 10-25-2003 11:28 AM
