engine/tranny combos? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2006, 09:53 PM   #1 (permalink)
View ninerjoe's Photo Gallery
Hi guys, I have a few questions that I hope you can help me with. Not sure what section to post in, so figured I'd start here:
I am planning on building a kit car soon, and would like to use Toyota power. The car only weighs 1300 lbs., so a stock motor will work fine. I'm looking for an engine that is NA, up to 2.0 liters and has 150-220 hp. My problem is the car is RWD and I have no idea what transmissions will work with certain engines. I'm leaning towards the 3sge, but don't know what tranny I can use with it. Are there other engines you guys suggest? Is there a list of engine/tranny combos that are a simple bolt-on?
Hope you can help. Thanks.
Joe
ninerjoe is offline   Reply With Quote
Old 11-02-2006, 11:21 PM   #2 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Can you make it a front wheel drive kit car? Doesn't matter really. If you are going to use an 3sge (from a celica) engine than just get the tranny that comes with it. You can buy a whole front clip and it will have the tranny already with it....
This may help too:
FWD's answer to the RWD transmission info here on club4ag, All the information may not be the same in every country..
*C50 - AE92 SR5 5-speed, 2E engine, most 4AF cars(ae92 sedans)
*C52 - AE92 GT-S 5-speed, Corolla GTi, euro 4af AE92(different final drive), Early AE101, 7afe AE101(different final drive), 4AGE AE82's
*C56 - AE101 5-Speed, AE111
*C59 - 1ZZ 5-Speed
*C60 - Celica GT-S 7th gen, Corolla XRS
*C65M - SMT from MR2 Spyder.
*C150 - Echo
*C160 - AE111 Levin/Trueno 6 Speed(lsd and none lsd versions)
*E51 - AE92 4AGZE 5-Speed(Zenki)
*E52 - 89-91 Camry 2VZFE
North America
*E53 - 92-93 Camry 3VZFE
North America 5-Speed
*E58 - AE92 4AGZE 5-Speed(Kouki), AE101 4AGZE
*E153 - 97-00 Camry 1MZFE, 99-00 Solara 1MZFE
*S51 - 87-91, 92-96 3SFE and 5SFE Camrys
C50 North American AE102 version 93-97 Corolla 4AFE
1st: 3.545
2nd: 1.904
3rd: 1.310
4th: .969
5th: .815
final drive: 3.722
C52 North American AE102 version 93-97 Corolla 7AFE
1st: 3.166
2nd: 1.904
3rd: 1.310
4th: .969
5th: .815
final drive: 3.722
C52 88-91 AE92 4AGE
1st: 3.166
2nd: 1.904
3rd: 1.310
4th: 0.969
5th: 0.815
Final: 4.312
C56 North American Celica ZZT230 00-05, AE101, AE111 Levin/Trueno
1st: 3.166
2nd: 1.904
3rd: 1.392
4th: 1.031
5th: .815
final drive: 4.312
C59 North American Corolla ZZE110 98-02 1ZZFE
1st: 3.166
2nd: 1.904
3rd: 1.310
4th: .885
5th: .725
final drive: 3.722 03-UP ZZE130 Corolla ratios are the same except for a 3.941 final drive.
C60 All North American 2ZZGE(Celica, Matrix, Corolla XRS, Elise, *not Exige*)
1st: 3.166
2nd: 2.050
3rd: 1.481
4th: 1.166
5th: .916
6th: .725
final drive: 4.529
The 03-05 MR2 Spyder SMT(C65M)
1st: 3.166
2nd: 1.904
3rd: 1.392
4th: 1.031
5th: .815
6th: .725
final drive: 4.312(thanks naviles16v)
C150
1st: 3.545
2nd: 1.904
3rd: 1.310
4th: 0.969
5th: 0.815
Final: 3.526
C160 Levin/Trueno AE111 6 Speed
1st: 3.166
2nd: 2.050
3rd: 1.481
4th: 1.166
5th: 0.916
6th: 0.725
Reverse:
3.250
Final Drive
: 4.529
E51 Levin/Trueno AFM 4AGZE
1st - 3.230
2nd - 2.045
3rd - 1.333
4th - 0.972
5th - 0.820
Final-3.933
E52 89-91 Camry 2VZFE North America
1st: 3.230
2nd: 2.045
3rd: 1.333
4th: .972
5th: .820
final drive: 3.933
E53 92-93 Camry 3VZFE North America
1st: 3.538
2nd: 2.045
3rd: 1.333
4th: 1.028
5th: .820
Final drive: 3.625
E58 Levin/Trueno MAP 4AGZE
1st - 3.214
2nd - 2.045
3rd - 1.333
4th - 0.972
5th - 0.820
Final-3.944
E153 97-00 Camry 1MZFE, 99-00 Solara 1MZFE
1st: 3.23
2nd: 1.913
3rd: 1.258
4th: .918
5th: .731
final drive: 3.933
S51 87-91, 92-96 Camry
1st: 3.538
2nd: 1.960
3rd: 1.250
4th: .945
5th: .731
final drive: 3.736(SV21)3.944(SXV10)
c150 - Fitted to 2e-elu (and other lower spec models) EP71 Starlets.
They ran from nov 1984 through to late 1990 I believe although on the lower spec EP80's I think the same box is used.
c152 - Fitted to 2e-telu (Turbo S Version) EP71 starlets. Slightly different ratios and they have a slightly stronger input shaft. There are some slight casing changes.
Both the c150 and c152 come non-lsd although one can be fitted. As far as I'm aware only TRD make these and they may be discontinued.
c52 - Fitted to 4e-fte (GT) EP82 starlets. Much stronger than the c15x's listed above, larger diff and gearsets. Very similar to 4age c52 internally although do have a different final drive ratio and casings. The bellhousing for example is a fair bit different.
Thanks to everyone that helped.
diver9000 is offline   Reply With Quote
Old 11-03-2006, 09:03 AM   #3 (permalink)
CCC-norchap
sportrally88's Avatar
View sportrally88's Photo Gallery
those are all fwd trannys .....t50 and and 4age 20v should do you just fine
sportrally88 is offline   Reply With Quote
engine/tranny question ninerjoe MR2 Forum 6 11-08-2006 06:47 PM
engine/tranny question ninerjoe Celica Forum 6 11-02-2006 10:42 PM
engine/tranny question ninerjoe Supra Forum 4 11-02-2006 12:33 PM
Is this a possible MR2 engine/tranny swap? Precisionsick MR2 Forum 6 07-14-2005 01:56 AM
'74 engine/tranny swap pjsammy Archived Corolla threads 2 01-13-2005 08:23 AM
