4AGE, 1986 Corolla FXGT - Engine missing? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2006, 03:14 AM   #1 (permalink)
View Fl440's Photo Gallery
Gday all,
Can anyone help?
I seem to have a small miss at around 2000 Rpm when accelerating in 3rd of 4th, it will give a small cough before accelerating away.
Doesnt do it all the time, but certainly at moderate throttle settings it tends to happen
anyone have any suggestions?
cheers Mark
Fl440 is offline   Reply With Quote
Old 11-06-2006, 07:31 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Bad plugs maybe.
BTW the title is deceiving.. I thought your whole motor was missing.
Old 11-06-2006, 08:10 AM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
so did I ren lol
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 11-06-2006, 11:32 AM   #4 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
Originally Posted by REN69
Bad plugs maybe.
Same here
retiredat44 is offline   Reply With Quote
Old 11-06-2006, 02:32 PM   #5 (permalink)
Gameroom cash: $134355
um, i didn't.....
in any case.....
pull the plugs and replace if needed.....
check your wires.... 2k rpm in 3rd or 4th will put a load on the motor.... wires tend to jump spark when the engine is more at load.....
get a manual and check the resistance of your coil (just a good idea)
check your ignition timing
Old 11-07-2006, 02:17 AM   #6 (permalink)
cheers all,
sorry about the title, ooops!
appears to be a dodgy lead, and also replaced the Dizzy cover, which inside looked like it hadnt been changed for a long time! didnt have much left on points 3 and 2!
Still, 350,000km, same engine, runs immaculate and still not using any oil, you have to love the 4AGE!!
Old 11-07-2006, 07:04 AM   #7 (permalink)
KDM is in
REN69's Avatar
"missing" and "misfiring" are two different words around here.
350,000km not bad, that's what my 89 GTS has right now. It would be back on the road for winter already but I have a stubborn bolt that stripped and won't come out. I'll be back at it this weekend I hope.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 11-07-2006, 09:24 AM   #8 (permalink)
View GT 20 valve's Photo Gallery
try plug leads...sounds like they mite be arcing with the body when higher voltages are being pushed thru them.
GT 20 valve is offline   Reply With Quote
Old 11-07-2006, 05:10 PM   #9 (permalink)
KDM is in
REN69's Avatar
That's true usually nicks and cuts on the wires eventually let the electricity through. I had one of my Civics do this a long time ago, the wire had a cut and it would arc the electricity from the wire to the nearest metal cable (speedo I think, can't remember) and the motor would missfire. It was kinda cool watching the electricity arc though.
20r Engine Rebuild From Hell! nwdetectorist Off Topic 6 10-20-2007 09:19 AM
20R ENGINE REBUILD FROM HELL! (Part Three) nwdetectorist Pre-88 Toyota Pickup/Hilux 1 08-09-2007 07:30 PM
Engine hesitated and how I fixed it, 1998 Corolla Anthony1 Archived Corolla threads 8 03-23-2007 08:18 PM
Raspy engine noise when I down shift or let off gas pedal. 2005 Corolla XRS beholder Archived Corolla threads 5 07-08-2005 07:09 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
