is it possible to supercharge a 4a ge 20 valve? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2006, 08:09 AM   #1 (permalink)
View GT 20 valve's Photo Gallery
Question is it possible to supercharge a 4a ge 20 valve?
I own a 4a ge 20 valve corolla,and was curious to know if anybody knows if its possible to simply put the supercharger from a 4a gze onto it...or would it be a special make-up job?or would it be beyond the realm of realism to consider a nitrous oxide kit for it?
GT 20 valve is offline   Reply With Quote
Old 11-07-2006, 09:53 AM   #2 (permalink)
View jon_570's Photo Gallery
You will find that the supercharged engines have ceramic coated pistons and a lower compression ratio.
It would be quite easy to put the supercharger on, but I would definitely be sourcing GZE injectors, MAP sensor and ECU at very minimum -
Being that the 4A-GE's have a higher compression ratio, you would definitely need a good intercooler, low boost and decent 98RON fuel to avoid detonation.
It would be far cheaper and WAY easier to just buy a 4AGZE (about $950). on ebay you can get it with the ECU and everything
jon_570 is offline   Reply With Quote
Old 11-07-2006, 10:19 AM   #3 (permalink)
Gameroom cash: $147537
Not sure if it will bolt up. 20V got ITB and the GZE doesn't. You can add adaptor plate but the whole thing may hit firewall.
Old 11-07-2006, 02:02 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Anything is possible if you have money and time.
Old 11-07-2006, 03:43 PM   #5 (permalink)
The TN Member
View punter's Photo Gallery
As above.
But it would be less messing around to just turbo it.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 11-07-2006, 04:00 PM   #6 (permalink)
Still need new intake. Stock 20V intake won't take much (if any) boost.
Old 11-07-2006, 04:19 PM   #7 (permalink)
The TN Member
Yes new airbox, the quads are fine though.
Old 11-08-2006, 05:36 AM   #8 (permalink)
Thanx everyone for your input.appreciate your help!
Old 11-08-2006, 06:39 PM   #9 (permalink)
Gameroom cash: $134355
it's been done..... bolts to the block... but you need to reroute the charge pipe coming from the s/c..... it doesn't clear the throttle bodies.....
4AGZE or 20 valve? mistafista Archived Corolla threads 5 06-21-2002 09:13 AM
Thinking of a 20 Valve for my SR5 Xenon Archived Corolla threads 6 01-23-2002 09:49 PM
