Mechanic Advised Me to Sell My Corolla!?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2006, 12:20 PM   #1 (permalink)
View jklivingston's Photo Gallery
I took my 1999 Corolla to a mechanic due to a break in my car's electrical circuit. (Details: http://www.toyotanation.com/forum/t162670.html)
After fixing the car, the mechanic advised me to sell the vehicle before it's oil rings fail (Its got 110K miles on it). He said this is a common problem with the 1.8L engine and that it would cost around $3K to fix. Is this really a common problem?
jklivingston is offline   Reply With Quote
Old 11-07-2006, 12:25 PM   #2 (permalink)
4AFESPEED
TheOtherCarolla's Avatar
View TheOtherCarolla's Photo Gallery
3k to put new rings in???
I'd say get a new mechanic.
93' Prizm - Friend wrecked it R.I.P. 10-19-07
89' 240sx - Now daily driver, rb20 swap
FMIC, 11psi, 3in exhaust..
TheOtherCarolla is offline   Reply With Quote
Old 11-07-2006, 12:28 PM   #3 (permalink)
Gameroom cash: $147537
3K you can swap in another engine. Oil burning is common for the ZZ family (1ZZ-FE, 2ZZ-GE).
Old 11-07-2006, 03:27 PM   #4 (permalink)
PsychoCoder
View psychocoder's Photo Gallery
$3000 for new rings??!!??!! I just rebuilt a 93 7AFE (rods, rings, pistons, valves, valve seals, valve springs, oil pump, timing belt setup,all gaskets/seals,professsional head job) and it only cost me $1045, so if he's going to charge you $3000 to change the rings you're being hosed man. But if you're willing to pay that for new rings Ill do it for $1500
psychocoder is offline   Reply With Quote
Old 11-07-2006, 06:51 PM   #5 (permalink)
View stubborn1's Photo Gallery
Why bail out at this point? You've got a 99 with 110k miles, so most of the depreciation is done. If it does start burning oil, you can always drive it into the ground or sell and take a hit on the bad engine. Selling a vehicle because a problem MAY occur is just bad advice.
My 98 has the bad rings issue. For the past 25k miles, i've been adding a quart every 800-900 miles with no other side effects. I'm on the drive it into the ground path.
stubborn1 is offline   Reply With Quote
Old 11-07-2006, 09:14 PM   #6 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
don't listen to them lol
Fix it
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 11-09-2006, 05:08 PM   #7 (permalink)
As far as I know, it isn't leaking oil now, the mechanic just thought I should sell before it starts. I plan to keep the car as long as possible.
Old 11-09-2006, 05:52 PM   #8 (permalink)
The TN Member
View punter's Photo Gallery
Then just keep it, ifs its not broken don't worry
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 11-09-2006, 08:54 PM   #9 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
If its not broken than dont fix it. Not much at this point you can do to prevent the rings from leaking. If they are going to leak than they are going to leak. Dont worry about it until then, just get an idea of what you want to do if and when it happens. Until then enjoy the ride.
diver9000 is offline   Reply With Quote
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
Corolla History/Generation Breakdown! Chris Corolla S Archived Corolla threads 8 07-10-2003 12:18 PM
