spark - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2006, 03:09 PM   #1 (permalink)
View rice's Photo Gallery
spark
my car engine bay is shaking after i installed new spark plug wires, how to fix it? thanks
rice is offline   Reply With Quote
Old 11-07-2006, 04:12 PM   #2 (permalink)
View tashirosgt's Photo Gallery
Perhaps one of your new wires is bad and your engine is missing on one cylinder. If you pull the wire on the cylinder that is is already missing the engine won't sound any worse.
tashirosgt is offline   Reply With Quote
Old 11-07-2006, 04:21 PM   #3 (permalink)
The TN Member
View punter's Photo Gallery
Check they are all clipped on at both ends.
Are these the ones that were too long?
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 11-07-2006, 09:35 PM   #4 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
I would check to see if all my plugs were tight, then check the firing order.
diver9000 is offline   Reply With Quote
Old 11-08-2006, 12:04 PM   #5 (permalink)
what do you mean clipped on both ends? you mean the wires cannot be touching each others through the plastic wrap? yes, these are the ones that were too long. Otherwise, everything seem to be running ok, just the shaking that never occurred before the new wires. Since i'm having a compression test done by a shope, will a compression test tell which cylinder is not getting enough spark/missing?
Old 11-08-2006, 12:56 PM   #6 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Cool
pne of the wires is messed up,, yu will have to find the messed up one and reset the ends.
(s).
retiredat44 is offline   Reply With Quote
Old 11-08-2006, 06:27 PM   #7 (permalink)
(s).
and how do you suggest i do that?
Old 11-08-2006, 06:37 PM   #8 (permalink)
The TN Member
I was meaning are they on the plug properly. same for the dizzy end.
If you get your old plugs you could use them to find the problem. just change one at a time, ie. you'll always have one old one and 3 new ones.
Old 11-08-2006, 07:04 PM   #9 (permalink)
Exclamation
How to find the wire that makes teh engine miss? you will have to pull each plug wire one by one with the engine running and find which one is screwed up. When the one that is bad is pulled there will be little to no difffence int he engine running smoothly. It will be a very noticiable difference, as when you pull a good one it wil run badly. Whne you pul the bad one, it wil make harly any difference. Then check the end you cut and/or attached the mteal clip and fix it..
You may be able to avoid shocks by wearing gloves.
Old 11-09-2006, 12:08 AM   #10 (permalink)
View 91gtssilvertop's Photo Gallery
make sure you put them in the right order
91gtssilvertop is offline   Reply With Quote
Old 11-09-2006, 01:42 AM   #11 (permalink)
thanks for everyones response, i will do what retiredat said maybe this week-end, thanks for everyones response, i will keep you guys updated
like i said, car runs perfect normal, as normal as when i had the old wires in, plugs are hand tighten, everything was done correctly
Help!! Removing stuck spark plug in Camry 2.2 skewe Camry & Solara Lounge 23 06-04-2007 05:45 PM
2005 Camry Spark Changing talley008 5th & 6th Generation (2002-2006 & 2007-2011) 11 11-28-2006 11:55 AM
Waste spark ignition touringcamry Camry & Solara Lounge 6 12-27-2005 03:35 PM
Intermittent spark 3ac Wallman Yaris, Vitz and Echo Forum 6 02-01-2005 12:17 AM
spark plug wires + spark plugs aleks77 Camry & Solara Lounge 4 09-13-2004 02:08 PM
