rough morning start ups - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2006, 10:23 PM   #1 (permalink)
View nova-rolla's Photo Gallery
i seem to have a problem with morning start ups. when i start up it seems to be bogging and idling like its got some high duration cams in it. it only does this for a few mins till the car gets goin and warmed up. any ideas?? i recently did plugs, plug wires, fuel filter, pcv valve, air filter, cap and rotor and o2 sensor. im wondering if my o2 sensor got fouled out since i was at one time having excessin oil blow by. like i said only for a few minutes then the car seems to be idling steady and no hesitants. this is on a 85 4a-lc carbed nova
nova-rolla is offline   Reply With Quote
Old 11-08-2006, 05:28 AM   #2 (permalink)
View GT 20 valve's Photo Gallery
did you try cleaning your carb?if not,i would recomend it.i would doubt its o2 sensor,as if their gone,it wont make any difference when it heats up,im sure it would stil run like a pig.
GT 20 valve is offline   Reply With Quote
Old 11-08-2006, 09:25 AM   #3 (permalink)
Infinitrium's Avatar
View Infinitrium's Photo Gallery
Is your choke working?
Infinitrium is offline   Reply With Quote
Old 11-08-2006, 09:08 PM   #4 (permalink)
some also suggest the choke. how would i go about adjusting or fixing the choke. is it attached to the carb? im new at car fixing and trying to do it on my own. thats why i like this 4alc engine seems easy to reach just bout everthing on on the motor. would a vaccum leak do this?
Old 11-09-2006, 12:13 AM   #5 (permalink)
View 91gtssilvertop's Photo Gallery
check your choke. can't be an o2 because they don't do anything cold. To check it remove the air cleaner top and see if the butterfly plate on the top of the carb is almost closed(after pumping the pedal once with a cold engine). as the engine warms up the choke should open.
91gtssilvertop is offline   Reply With Quote
Old 11-09-2006, 01:22 AM   #6 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Cool
be very careful when adjusting anything on the carb, even if you count turns and write them down, keep a notebook, it is very easy to lose facotry settings, and never get it back correctly. If the car is high mileage, it maybe time to rebuild. if it's a carb, If it's FI then could be time for rebuilding whatever parts where out.
retiredat44 is offline   Reply With Quote
Old 11-22-2006, 12:43 PM   #7 (permalink)
drive hard n drive fast
tireboy's Avatar
View tireboy's Photo Gallery
i had the same issue with my 86 nova ... there is a fix for it .. its in all data ... ya just need to make a few adjustments ill find it for ya it really helped big time... gm has posted the fix. in all data its in the drivability section under .. hesitation cold or hot ...drive hard n drive fast ..... tireboy
tireboy is offline   Reply With Quote
Idle speed too high upon start up... how to fix??? highlander04 General Discussion 21 01-30-2007 01:43 PM
avalon 2006 rpm start ups ocean7cake 3rd Generation (2005-2012) 4 11-20-2005 08:07 PM
87 supra wont start iwannadie Supra Forum 13 08-09-2005 03:17 PM
01 Rough Idle, Stall, Hard Cold Start anr 3rd & 4th Generation (1992–1996 & 1997–2001) 0 05-30-2005 12:50 AM
engine start problem n prake problem LWF Camry & Solara Lounge 0 10-25-2004 04:35 PM
