1999 corolla brake job.. Need some info.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2006, 11:09 PM   #1 (permalink)
View newbie212's Photo Gallery
Just got a 1999 corolla and was told I needed new front brakes.. The Stealer wanted $359 for rotors and pads and labor.. I've done pads before on my tacoma but never removed rotors.. How easy of a job is this on my corolla? I have access to air tools.. Do I just remove the caliper bolts and will the rotor fall off?? It cant be that easy... Any help would be appreciated.. Thanks
newbie212 is offline   Reply With Quote
Old 11-09-2006, 06:06 AM   #2 (permalink)
View GT 20 valve's Photo Gallery
in saying rotors...do you mean the brake discs?...if so,their handy to take apart.instead of loosening the 12mm bolts that are immediately visible when you look at the caliper,remove the two 17mm bolts that actually hold the caliper onto the strut,and the disc should pull off handy enough.if not,a tap of a hammer should persuade it off!
GT 20 valve is offline   Reply With Quote
Old 11-09-2006, 11:03 AM   #3 (permalink)
View tommytuttle's Photo Gallery
Canada
Yes it is that easy.
I've done them on my 2000.
The greatest problem I've had is the rims corroded to the rotor...
Once the wheels are off... no problem. Someone once told me to use a bungy cord or something to hold the caliper out of your way.. but I just balance it on the a arm.
tommytuttle is offline   Reply With Quote
Old 11-09-2006, 08:57 PM   #4 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Yeah its pretty much that easy. It would be handy if you could secure your calipers so as they dont pull on the brake lines. A coat hanger works well for holding the calipers out of the way in this instance.
diver9000 is offline   Reply With Quote
Changing Brake Help on 03 Corolla brhino692 Archived Corolla threads 6 03-16-2006 07:30 AM
Need Info Please! - Possibly Buying '99 Corolla FieroGT42 Archived Corolla threads 3 11-18-2005 01:06 PM
Corolla 1982 Brake problem reym Hardcore Tech and Competition 3 04-25-2005 10:55 PM
Brake Job on 86 GT Help natx808 Celica Forum 7 03-19-2003 01:16 AM
03 Corolla S & LE Owners - Firestone Recall Info Phi Archived Corolla threads 2 09-30-2002 11:24 AM
