Sticky Solenoid Symptoms? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2006, 04:10 PM   #1 (permalink)
View smharr4's Photo Gallery
I have a 1997 Toyota Corolla CE with a 1.4 I4 engine that is refusing to start.
The battery is good (multimeter tested), and I can hear it turning the starter (or at least it's a loud rattle like the starter is turning), but there is no cranking and no starting
Is this a sticky solenoid, or something else?
smharr4 is offline   Reply With Quote
Old 11-09-2006, 04:22 PM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
Yes, sounds like it..
retiredat44 is offline   Reply With Quote
Old 11-09-2006, 04:39 PM   #3 (permalink)
View Hemi3TC's Photo Gallery
A multimeter test of a battery does not mean the battery is good. The battery has to be tested under load to determine if it is really any good. Turn on the headlights then measure the battery terminal voltage is better than nothing.
h3tc
Hemi3TC is offline   Reply With Quote
Old 11-09-2006, 05:51 PM   #4 (permalink)
I did test the battery while under load, the DMM reported 11.94V.
Is there a procedure for replacing the starter solenoid, and is it a DIY job?
Old 11-09-2006, 08:37 PM   #5 (permalink)
View 91gtssilvertop's Photo Gallery
Loud rattle? Do you mean a loud repetitive clicking?
What's the battery voltage while trying to crank?
91gtssilvertop is offline   Reply With Quote
Old 11-11-2006, 02:56 PM   #6 (permalink)
Yes, it's a loud, fast, repeating clicking noise.
Battery voltage is 11.89V when trying to crank.
Old 11-11-2006, 06:04 PM   #7 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Did you try removing battery cable terminals and clean both the cable ends and battery posts with a wire brush?What about trying to jump start it with another vehicle? If battery doesn't have enough charge under load or a poor cable connection will make a loud clicking sound while trying to start.
90 GP is offline   Reply With Quote
Old 11-11-2006, 06:12 PM   #8 (permalink)
Jumpstarting the car did get it working, I thought it was just coincidence.
The battery is almost 4 years old, should I just get a new battery?
Old 11-11-2006, 09:57 PM   #9 (permalink)
Check voltage @ starter on both the main power cable and the start wire while cranking. Is it the same as @ the battery? If so check your starter ground and battery ground. If they're ok replace the starter. if low voltage @ either wire you'll have to check for poor connections or a bad wire.
it'll start when you jump because you're starting off with higher voltage. 14.5 from the jumper car as opposed to 12.5 or less from your battery.
Old 11-12-2006, 12:02 AM   #10 (permalink)
Cool
have the battery checked,,..
also any battery on year 4 is due to be replaced.. period..
Old 11-12-2006, 12:19 AM   #11 (permalink)
if problem was battery, he would not have 11.89 volts during crank.
Old 11-12-2006, 03:02 AM   #12 (permalink)
Hate to say this, but I'll need a bit more info.
Where is the starter on this car, and which cable would be which? I'm used to working on my Mercedes, I'm not as familiar with my Corolla as I should be.
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
