'93 Seatbelt repair - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2006, 11:34 AM   #1 (permalink)
View DarkNinja75's Photo Gallery
'93 Seatbelt repair
Basically, my driver and passenger side seatbelts don't retract. If I push them back up they have enough force to go back in, but otherwise they just stay extended. Anyone know if it's possible to fix this themselves, or has anyone done it?
DarkNinja75 is offline   Reply With Quote
Old 11-11-2006, 03:09 PM   #2 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $143400
View Piloter's Photo Gallery
Same problem...I've heard from a mechanic at a dealership that it could be something as simple as dirt in the top loops (not the actual retractor mechanism) causing it to stick. Easily tested--grab the belt just above where it comes out of the sill area, and tug it up and down there. If it moves freely, then it's just the top hangar that's gummed up...maybe some silicone spray would be of use?
If it's the actual retractor mechanism, there has to be some way to get to it short of just spraying some lubricant down in there.
...Although would that be a bad idea, necessarily?
WIP AE102.
Piloter is offline   Reply With Quote
Old 11-12-2006, 09:56 PM   #3 (permalink)
View TxMiniTruck's Photo Gallery
My wifes 93 corola has the same exact symptoms with the front seatbelts. Im goint to take them apart and see whats up because they should retract themselves.
Damon
Paris Tx
87 2wd extra cab long bed toyota pickup
TxMiniTruck is offline   Reply With Quote
Old 11-13-2006, 10:17 AM   #4 (permalink)
blb
View blb's Photo Gallery
The factory spring to recoil the seatbelts is very weak. About the only way to improve the situation is to take the retractor apart, pull the end of the seatbelt out of the plactic spool by removing the plastic pin in the loop, spin the spool a couple of turns tighter, then reassemble the belt onto the spool. Basically you are just preloading the spring a couple more turns.
blb is offline   Reply With Quote
Passenger Seatbelt Light Confused Pooka 1st Generation (1998-2003) 6 01-10-2007 06:28 PM
Chilton's Repair Guide or Toyota OEM repair guides DK Squall Camry & Solara Lounge 2 09-27-2005 04:14 PM
Toyota seatbelt repair policy chumley20 General Discussion 1 09-23-2002 05:26 PM
