How do I...? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2006, 11:37 AM   #1 (permalink)
View tnmk's Photo Gallery
How do I...?
How do I stop the engine from turning while I'm loosening the crank pully? Do I re-connect the battery and put it in D?
tnmk is offline   Reply With Quote
Old 11-11-2006, 12:09 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
You use the toyota SST or make your own. You see the two threaded holes, you can put M8 bolts in there and then use a prybar to hold it still.
Old 11-11-2006, 03:55 PM   #3 (permalink)
I'll try the M8's first. Otherwise I'm stuck till Monday when I can get to the toy dealer
Old 11-11-2006, 04:25 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
also one way to get the bolt off is to put a breaker bar on it, rest it on the floor and crank the starter to loosen it.
Old 11-12-2006, 10:24 AM   #5 (permalink)
That almost sounds scary. But I guess just a quick bump would do it. I think I'm going to make a tool at work tommorrow. It should be pretty easy to do. I don't happen to have a breaker bar. Used to, don't know what happened to it.
Old 11-12-2006, 03:37 PM   #6 (permalink)
niko3257's Avatar
View niko3257's Photo Gallery
have you tried air tools?
i can see a problem with hand tools but not air tools.
a good air gun will get it right off.
i just took my dads camry crank off 2 weeks ago.
his rubber fell apart on it and he needed a new one.
niko3257 is offline   Reply With Quote
Old 11-12-2006, 04:15 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
need a decent impact gun though
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 11-12-2006, 04:18 PM   #8 (permalink)
I thought about the air tools, but I don't have any or know anyone that I can borrow from and as often as i would use it, it wouldn't pay to go out and buy one.
Old 11-12-2006, 04:23 PM   #9 (permalink)
niko3257's Avatar
you know it. i only use Snap-On
Old 11-12-2006, 04:47 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
My engine would just spin the wrong way when I used airtools
Old 11-12-2006, 08:57 PM   #11 (permalink)
View stubborn1's Photo Gallery
I haven't tried it on a Corolla, but on other vehicles I've jammed a screw driver in the flywheel to keep it from turning. I have't looked close enough to see if there is access, but it's worth a shot.
stubborn1 is offline   Reply With Quote
Old 11-12-2006, 09:44 PM   #12 (permalink)
View nsiqui10's Photo Gallery
let the crank spin untill one of the pistons hits compression stroke, then u will have some resistance, then with a breaker bar and a hammer, give the bar a good wack, it should break free. but make sure u spin the crank till one of the pistons is on compression stroke
YEeEAa
nsiqui10 is offline   Reply With Quote
Old 11-13-2006, 04:55 AM   #13 (permalink)
Resident asshole
Flashmn's Avatar
Youre not supposed to turn the engine the wrong way, the bolt opens ccw, so how are you gonna spin the engine to compression and keeping it there when the engine turns cw. Theres a reason why theres the two bolt holes and why toyota has a special tool for it.
Old 11-13-2006, 04:46 PM   #14 (permalink)
Gameroom cash: $134355
actually what flashmn said before (about using a prybar against something.... the ground, or a control arm) and just 'clicking' the starter over works quite well....
i was taught to do that by someone who does more toyota work than anyone i know.... and have also found out that some guys at the toyota dealerships will do that as well -- it's faster
Old 11-13-2006, 04:52 PM   #15 (permalink)
Resident asshole
Flashmn's Avatar
just make sure the socket fits snuggly, if you manage to screw up the head.. whoops heh good luck with it.
