Turn Signal Trouble - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2006, 01:39 PM   #1 (permalink)
View Maciej's Photo Gallery
Turn Signal Trouble
Lately I have been having problems with my turn signal. When I turn my turn signal on, it works just fine, but when I want to turn it off the clicking sound keeps going at an even faster pace then when the signal is on. When the turn signal is in the off position, the lights are also off, but the clicking sound keeps going. I was told that this is not a fuse problem, because if it was, the turn signals would not be working. This problem also seemed to get worse as time went on. At first, the clicking sound would stay on for a few seconds after using the turn signal, but now, it is almost on constantly (which can be very annoying). It also sometimes turns the left turn signal on, randomly, even if the turn signal is in the off position. I'm not exactly sure if this is something I can fix on my own, but any suggestions would be appreciated. Thank you in advance.
P.S. '98 Corolla VE
Maciej is offline   Reply With Quote
Old 11-14-2006, 08:21 AM   #2 (permalink)
I was looking more into this problem and I found that it might be the turn signal relay. Is there a way I can test this myself to make sure that this is the problem before purchasing the part?
Old 11-14-2006, 08:27 PM   #3 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Get one from a junkyard and test it out. Also, ever think about it being the actual blinker switch itself. (the arm on the side of the steering wheel)?
diver9000 is offline   Reply With Quote
Old 11-16-2006, 01:23 PM   #4 (permalink)
I'll have to check that out.
Old 11-16-2006, 01:44 PM   #5 (permalink)
View toyomoho's Photo Gallery
The power to the turn signals may also go through the hazard light switch. Might check this switch also. The turn signal blinker unit should be a low cost item.
Where are the turn signal fuses? (3rd party blinkers) PICS mike6789 Camry & Solara Lounge 5 05-22-2006 12:43 PM
Flashing lights touringcamry General Discussion 9 05-04-2006 10:52 PM
Turn signal relay/flasher gimme55 1st Generation (1998-2003) 1 03-27-2006 09:22 PM
Check Engine Light Problem Aaagogo Celica Forum 7 09-02-2004 06:46 PM
Turn Signal Problem pinoy Celica Forum 0 10-13-2002 10:57 PM
