Ae86 and ae92 hydrolic clutch fluid? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2006, 03:30 AM   #16 (permalink)
The TN Member
View punter's Photo Gallery
$200's alot, would be about half that here. And your dollar is stronger.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 11-16-2006, 07:07 AM   #17 (permalink)
View micro214_kp61's Photo Gallery
$200 for both sounds about right. but i could be wrong since it's an OEM part. MC alone cost me around $100 for an aftermarket one but i got $20 back when i returned my old MC.
freakinbox... AE86 parts are not cheap man.
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 11-16-2006, 09:38 AM   #18 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Cool
Originally Posted by freakinbox
yea, when I get it home I am checking the master and slave. Looks like the slave on the 92 is leaking :|... but yeah here's a question then.. on the 86 is the slave on the outside of the tranny like on my ae92 sr5? or is it on the inside like some of the cars that came into the shop that I worked at?
get a rebuild kit, seals,,,, get some emery cloth (very fine grade), since it is cast iron, you can clean and smooth out the roughness and corrosion the bore in the cylinder. put the new seals in... and walla... you have a rebuilt hydraulic cylinder. Don't ever use the emry cloth on aluminum hydraulic cylinders,,,, it will ruin it, cast iron is ok... same with brake cyliinders... only on cast iron ones....
or if you can get new for a really good price do that,, but the rebuild kits used to be dirt cheap.. also, when you loosena nd tighten the bleed valves, be very very careful, they are very small and weak, can break easily,, be very careful... use a self bleed kit (cheap at auto parts stores..)
retiredat44 is offline   Reply With Quote
Old 11-16-2006, 12:09 PM   #19 (permalink)
operation boro thunder
View project trueno's Photo Gallery
Yes about 200ish CDN for BOTH OEM replacement from the dealer.
IIRC it was 130ish for the clutch MC, 70-80 for the clutch slave, mind you i had employee discount but you work at a shop so you get shop discount anyway.
They are all greased and holes plugged up, ready to drop in just like any other OEM part.....
The idea of spending less and rebuilding a part is great, but considering the clutch MC is a pain to RE & RE just drop in a new one you know will work. Saves you from headaches in the future.
project trueno is offline   Reply With Quote
Old 11-16-2006, 04:39 PM   #20 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I don't work at a shop anymore Lol, I plan to hit my friend up who works at toyota for the parts
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
ae86 or ae92. Messed up ae92 rdyzz Archived Corolla threads 2 04-25-2004 12:21 PM
