cleaning engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2006, 05:28 PM   #1 (permalink)
View motu 56's Photo Gallery
cleaning engine
I was cleaning off my motor with gunk and simply green and now the car will not start. I took off the cap and it was dry inside where do I look next ? Thanks for your help.
motu 56 is offline   Reply With Quote
Old 11-18-2006, 05:35 PM   #2 (permalink)
View toyomoho's Photo Gallery
Check for spark and if none, work your way back through the ignition system. Areas to look at are the coil, igniter, distributer cap, etc. A TN history search will result in many threads about this cleaning then no start issue.
Old 11-18-2006, 07:10 PM   #3 (permalink)
View 91gtssilvertop's Photo Gallery
make sure there is no water down the spark plug tubes
91gtssilvertop is offline   Reply With Quote
Old 11-18-2006, 10:03 PM   #4 (permalink)
View newbie212's Photo Gallery
Did you cover the distributor and the alternator? Check all connections in the engine compartment and make sure nothing is loose or unplugged....
newbie212 is offline   Reply With Quote
Old 11-18-2006, 11:16 PM   #5 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
The car will not start. Do you mean the starter wont spin, or the engine wont turn or the engine will not fire, or something else?
diver9000 is offline   Reply With Quote
Old 11-19-2006, 07:35 AM   #6 (permalink)
The engine spins but will not fire up. How do I go about drying these components. I appreciate the many posts so far.
Old 11-19-2006, 09:35 AM   #7 (permalink)
niko3257's Avatar
View niko3257's Photo Gallery
whenever i wash under the hood i always put a plastic bag over the distributor.
the most important thing.
check your distributor again. take the cap off and let it air dry. or if you
have a air gun hit it a few time to evaporate the water.
also check your spark plug tubes. sometimes the wires don't hold
a good enough seal and water gets in.
just make sure everything is dry especially all electrical components.
it should start back up.
niko3257 is offline   Reply With Quote
Old 11-19-2006, 10:20 AM   #8 (permalink)
[quote=niko3257]whenever i wash under the hood i always put a plastic bag over the distributor.
I'd cover the alternator too!!
Old 11-19-2006, 10:22 AM   #9 (permalink)
View jon_570's Photo Gallery
yea..water..even a little bit in the spark plug holes will mess the car up..i had a lil bit in cylinder #4 and it kept misfiring and i had to get a shop vac with a crevice attachment to get it them i had to cram paper towels down it to get it out...then i let it air dry the rest of the day..good thing it was 80 degrees out then
jon_570 is offline   Reply With Quote
Old 11-19-2006, 04:34 PM   #10 (permalink)
I checked and I am not getting any spark?What could possibly be the cause?
Old 11-19-2006, 05:13 PM   #11 (permalink)
No spark from the coil or from the plug wires?
Old 11-19-2006, 05:59 PM   #12 (permalink)
No spark from the spark plug.
Old 11-19-2006, 07:08 PM   #13 (permalink)
Check the spark coming from the coil itself. If no spark, check the wiring and harness plugs to coil, igniter, etc.
Old 11-19-2006, 08:32 PM   #14 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
a. Let it sit for a few days till the motor dries off.
b. Get a Shop Vac and either vacuum the water out OR use the blower feature to dry off the motor(may take a while).
A combination of b+a worked for me, took maybe a couple of days till the car started fine.
Old 11-20-2006, 10:37 AM   #15 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
check the dizzy, if it got wet, very well could be your problem. I got a dizzy laying around if it turns out to be your problem. E-mail me at ghost_ryder35@yahoo.com if you want it.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 09:38 AM
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
Increasing Horsepower in an AE92 azpriz90 Archived Corolla threads 5 01-11-2005 07:47 PM
Engine Cleaning, Lotsa Questions. kf4zra Camry & Solara Lounge 13 12-30-2004 12:18 AM
cleaning engine bay methods? PoR2GeEzCamry Camry & Solara Lounge 6 03-20-2004 11:55 PM
