Shifting..w/out clutch? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2006, 12:40 PM   #1 (permalink)
View HammerDown's Photo Gallery
USA Shifting..w/out clutch?
Just wondering if anyone has tried to shift w/out using the clutch.
Now on my big rig 9 speed shift up/down is easy w/out the clutch...once ya know the shift point rpm areas.
My 06 will come out of gear quite easly w/out the clutch but I haven't had the nerve to try and get it in gear w/out the clutch...yet
HammerDown is offline   Reply With Quote
Old 11-19-2006, 01:50 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
And the point being?
big rigs generally have straight cut teeth and you can do it, just like with motorcycles, but dont do it with the car. I really fail to see the point in shifting without the clutch.
Old 11-19-2006, 01:57 PM   #3 (permalink)
View AndrewE's Photo Gallery
shifting without the clutch or "powershifting" is just using the throttle to change gears
when you shift up just pull the shifter out of gear and hold it into the next position, when the rpms drop to the right level it will engage that gear
downshifting is the reverse procedure where you have to increase the revs to find the sweet spot
AndrewE is offline   Reply With Quote
Old 11-19-2006, 03:20 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
it's a good thing to be able to do it your clutch ever fails you, espicially with a car with a cable clutch.
you have to be at the EXACT rpm to do it. I just do it by holding the shifter and giving it a little pressure against the stop, it will allow the shifter in at the proper time and the shifter will slide into place. Same type of theory for downshifting, but it's harder. I say neutral and use the brakes if it was to happen.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 11-19-2006, 03:43 PM   #5 (permalink)
View 94_Rolla_Guy's Photo Gallery
Yes it is possible to shift without the clutch, but theres one main difference between a big rig and a little dinky car tranny, syncro's, on a big rig there are none so no problem thats the way its supposed to work....
On a car the syncros are there to match the speeds to prevent grinding, when you shift with the clutch the syncros only have to match the input shaft speed if you try to shift without the clutch you now need the syncros to match the engine speed along with the input shaft, basically its extremely hard on the syncros and will wear them out prematurely.
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 11-19-2006, 05:07 PM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I have one word for this thread.......
CRUNCH!!111one
Old 11-19-2006, 05:16 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
and synchros being a soft metal such as bronze they wear out faster than you can say "I just fucked up my tranny"
Old 11-20-2006, 04:28 PM   #8 (permalink)
Thumbs up
And that above is the answer I was looking for..."syncros"...and thank you sir!
Old 11-21-2006, 03:55 AM   #9 (permalink)
View Ninja7's Photo Gallery
Yes it can be done. Being a former heavy equipment mechanic and big rig driver I knew how the operations of a transmission both automobiles and big rigs. One day my clutch slave blew and I needed to get back home so instead of calling a tow truck I drove my car back home. At a dead stop I had the car in gear and started the car and then shifted with out using the clutch. I just revved the motor slightly to match engine speed with the transmission speed and the gears shifted easily.
Ninja7 is offline   Reply With Quote
Old 11-21-2006, 05:43 AM   #10 (permalink)
Vroom?
freakinbox's Avatar
exactly, there is a point to learning it... for situations like that. But I wouldn't do it regularly... No point
Old 11-21-2006, 08:22 AM   #11 (permalink)
View dgoodhue's Photo Gallery
I have played around with it. Its actually quite easy up shifting, just take your foot off the gas and a normal (in terms of speed) shift will do, it will just pop into place.
The tranmission will grind if the RPM of the engine is lower than the RPM of transmission. This is key. So usually on an upshift, the engine rpm's fall slower during a shift than time to change gears. For downshift you have atleast match or exceed the rev for the tranmssion to pop into place. You really need to know your cars gearing/rpm inside and out before attempt this regularly. If you want to practive it, attempt the shift with the clutch first and note th eRPM/speed and then try it again without the clutch. I alway try to exceed (over estimate) the RPM a little because if you get too cute with match the rpm and miscalculate, the grind of the gear box will rudely remind you that you screwed up...
Dave
02 Highlander
dgoodhue is offline   Reply With Quote
Old 11-21-2006, 08:37 AM   #12 (permalink)
In terms of racing. I always prefered the WOT speed shift (ie stab the clutch to release it so I could get it out of gear.) I have tried the clutchless racing, but I always had to release the gas to get the engine of gear and co-ordinate it with my hand. I only tried this on my friend beater that was going to a junk yard, but I screwed it up too many times on that beater that I was afraid to try it my car.
Dave
02 Highlander
Clutch, Gear shifting 05 taco cchukan 2nd Generation (2005+) 12 10-19-2006 01:35 AM
no clutch shifting 80toy Pre-88 Toyota Pickup/Hilux 8 11-28-2005 09:14 PM
UPDATE: Clutch problem canadianae92 Archived Corolla threads 2 10-29-2005 05:13 PM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 07:47 AM
