Figured I would repost since the car is now fixed. The car had a burned/leaking exhaust valve on cylinder #2. I pulled the head/turned it upside down and sprayed the #2 valves with some pb blaster. One of the exhaust valves let all the fluid through almost immediatly.
BTW, I got a 11K head off a 2004 Pontiac Vibe for $106 at a local salvage yard. Cleaned it up, checked for warpage and checked the valve lash on it. Got a head set on Ebay for $50, and a head bolt set from Headbolts.com for $46 shipped. After some misc. supplies/clamps I was at about $225 for the entire job.
I also found a shortcut on this job. Alldata lists book time @ 8hrs, I got it done in 6. It tells you to pull the front cover off to get the head off. What I did was pulled the valve cover, pulled the upper front cover bolts and 2 studs that go into the head, set the engine at TDC, pulled the timing tensioner and then the cams. There was also a bolt that held the timing chain guide in place that I carefully removed without dropping it down into the engine. It was accessable after the cams were pulled. Then the head came right off.
When I went to install the head, I added a little RTV to the exposed front cover and slid the head into place. Bolted it down and reinstalled everything and I was golden.
