'01 Prizm using oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2006, 11:18 PM   #1 (permalink)
Old Man Car Owner
View Mark Larson's Photo Gallery
Unhappy '01 Prizm using oil
Hey all, I have an '01 Prizm with about 77k miles on it. I've owned the car since June of this year and have noticed that it burns a lot of oil. I have used Supertech 5w30 synthetic but it still burned a lot.
In fact, I recently did a 2-day roadtrip, sustaining 80-85 the whole way, and the dipstick was almost dry each morning after covering about 700 miles every day. Took a couple of quarts to get it to full.
Any idea if this is the norm for these engines? I've had 15 year old domestics and a 10 year old Mazda which burned less oil (but those domestics had their own problems).
Right now I have Supertech dino 10w40 in it, trying some thicker oil to see if it'll help. Its still burning, but I haven't been driving much so I don't know if the rate is the same.
Mark Larson is offline   Reply With Quote
Old 11-20-2006, 12:01 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
there was a designt flaw which caused the rings to stick on the pistons and the engine to burn alot of oil. for some reaon some oils seem to coke up behind the rings and stick them inplace allowing oil to pass into the combustion chamber and burn. i'd suggest trying some oil additives like marvel mystery oil or something else that is claimed to unstick rings. i'm spacing out on the other one i'm trying to think of right now.
Old 11-20-2006, 02:25 AM   #3 (permalink)
View 94_Rolla_Guy's Photo Gallery
hello welcome to the oil burning family, less common on the 1ZZ-FE but still a problem, the majority of the problems reside on the 7A-FE (93-97 corolla 1.8L) just search "7A-FE oil burning" or similar stuff
Over the two different engines i have had in my car both have burned oil.. I have played around and found that some oils burn less (castrol GTX 10W-40) and castrol products in general seem to work well. i have tried a few different flushes and treatments with next to no luck most of the time the treatments increase the consuption.
My advice is let it warm up a little like until the temp gauge reads something, run it gently until up to temp, keep the oil no more than 1/2 a quart down, more can cause unstable oil pressure hence engine damage.
do this and you should see the consumption go down and become a little more manageable
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 11-20-2006, 03:00 AM   #4 (permalink)
Old Man Car Owner
Yeah I try to check the oil every few days and add as necessary, but the overwhelming feeling is that a 2001 Toyota should not need to be babied like that. With just 3.9L of oil capacity, its all too easy to starve the engine.
Its the VVT-i model, does that mean its the 1ZZ-FE? Wasn't that good for a bit more hp in the Celica?
Old 11-20-2006, 10:17 AM   #5 (permalink)
Bitter's Avatar
oh no no no, the early 1zzfe's are notorious for sticking the rings, alot more than the 7afe's.
Old 11-20-2006, 12:37 PM   #6 (permalink)
View dgoodhue's Photo Gallery
My 02 has 56K miles on it and the previous woman owner seemed to baby the car (I have the oil change records) I am basically not buring any oil (last oil was down 1/4 quart) All I know is that I am going to be BS if this car starts burning oil anytime soon. I bought it to be reliable and get good gas mileage.
Dave
02 Highlander
dgoodhue is offline   Reply With Quote
Old 11-20-2006, 03:08 PM   #7 (permalink)
View tnmk's Photo Gallery
Personally I'm inthe middle of replacing rings and valve seals in my '93. It only has 57,000 miles on it. I was burning about as much as you say you are.
Cylinders look good and it's not gummy inside. I'm hoping my little "rebuild" will do the trick. It's a lot of work to do, but the car is in excellent condition, so as long as it stops burning oil, I'll be happy.
tnmk is offline   Reply With Quote
2.7L oil capacity incorrect gonesurfing 2nd Generation (2005+) 34 02-11-2011 12:09 PM
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
Sure was fun changing my oil today... Infinitrium Archived Corolla threads 18 10-12-2006 08:38 PM
motor oil mishap minime3 3rd & 4th Generation (1992–1996 & 1997–2001) 15 05-14-2006 09:32 PM
Help!! Oil Puddle Under Engine Structureboy Camry & Solara Lounge 12 01-17-2003 12:04 PM
