89 corolla problem help please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2006, 12:07 AM   #1 (permalink)
View knoxtoy87's Photo Gallery
i have a 89 corolla 4af . i was driving out of my driveway and it just stopped and locked up, i can't move. i tried all gears even neutral and it still doesn't move. i think the problem could be caused by no oil in the differential case. i recently changed the driveaxles and i think it leaked out all the oil, but i did put transmission oil. is it split into two? my transmission could be screwed. i had to lift the front with a jack and push it out of the way. what you think?
knoxtoy87 is offline   Reply With Quote
Old 11-20-2006, 10:32 AM   #2 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
why did the fluid leak out? that could very well be your problem. It wont even move in neutral? Definetly sounds like something locked up, if there is no fluid in the tranny that could of popped a pin out of the tranny and locked it in gear, and or the axel poped out of the tranny. check it out and let us know
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 11-20-2006, 12:56 PM   #3 (permalink)
i just check the level of the transmission fluid. it was empty!! i just added 3 qrts. the car kinda moves altho i gotta press the pedal a bit harder. i dont feel the kick when i change through gears. this is a 3 spd automatic by the way.
Old 11-20-2006, 03:03 PM   #4 (permalink)
View toyomoho's Photo Gallery
Running the transmission out oil may have caused a clutch pack, brake or bearing to seize up. Seeing how the trans seems to still be binding a little may mean trouble in the future. From what happened to you, it could be the diff and trans oil systems are interconnected. Keep an eye out for leaking fluid.
Old 11-20-2006, 06:54 PM   #5 (permalink)
car is working now. the transmission fluid had to kick in.
Old 11-20-2006, 10:36 PM   #6 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
i think the problem could be caused by no oil in the differential case. i recently changed the driveaxles and i think it leaked out all the oil, but i did put transmission oil. is it split into two? my transmission could be screwed. i had to lift the front with a jack and push it out of the way. what you think?[/quote]
Yeah, theres a real good possiblity that one of the problems may be NO fluid in the transmission. "I think it leaked out" You dont know if your tranny is leaking? When you changed the drive axles did you check or refill the missing fluid?
diver9000 is offline   Reply With Quote
Old 11-21-2006, 06:58 AM   #7 (permalink)
<<<<<<j a m m e r>>>>>>
robbo_james's Avatar
View robbo_james's Photo Gallery
yeh....when refilling your tranny leave the oil can in the sun... it makes the oil runnier meaning it will slip though all the craks better...
robbo_james is offline   Reply With Quote
Old 12-02-2006, 03:17 AM   #8 (permalink)
is there a oil seal at the eng of the cv axles going into the differential? bcoz it's leaking oil from both ends. i think all the oil drained out from there.
Old 12-02-2006, 05:56 AM   #9 (permalink)
diver9000's Avatar
Hey knox, not being funny but there has to be a seal at the tranny end otherwise you will leak gear oil or ATF (whichever you have). You should have a rubber boot near the splines that go into the transmission. There is a thread on here about installation of the CV axles. When you did your installation did you "tap" your axle back into the tranny, or just set it in place? There is a clip on the cv axle that has to sort of snap into place. You might be better off getting a shop manual and really spending some time looking at what and how your car is suppose to be put together. That way you will know next time what to look for. Good Luck, I hope you get it fixed.
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
Corolla Altis 1.6 (AT) - Problem, help! lolipop Archived Corolla threads 1 03-11-2005 03:02 AM
ae92 corolla 91' problem help!! pcboy123 General Discussion 1 12-28-2004 03:08 PM
Corolla 91' Problem faisal Archived Corolla threads 4 02-25-2004 02:31 PM
