05 Corolla Tranny Fluid Change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2006, 04:51 PM   #1 (permalink)
View prophase's Photo Gallery
Peeps,
I read the service schedule over 2 times and nowhere did I see when to change the transmission fluid on the 05 corolla.
Can anyone advise when Toyota advises to change the tranny fluid on this year corolla??
Thanks.
prophase is offline   Reply With Quote
Old 11-20-2006, 10:22 PM   #2 (permalink)
View toyomoho's Photo Gallery
Toyota uses a long life fluid. It has scheduled intervals for fluid inspection but none for fluid changes. From what I understand the dealer has a color chart to compare the cars fluid to. If the fluid is too dark as per the chart it needs changing.
There has been a lot of discussion on other TN Toyota model forums about when to change this long life fluid. You might do a history search. The figure that comes up a lot is 30K miles. Who knows how long this long life fluid lasts. Unfortunately dirty, overheated and warn out fluid is the leading cause of transmission failure. Under Toyota’s maintenance plan, the fluid will most likely be first changed long after the warranty has expired.
Old 11-21-2006, 11:51 AM   #3 (permalink)
Thanks, that would explain why there is nothing in the guide about it.
To play it safe I will have it changed at 30K. My wife does not drive it that hard and she takes it easy but better to maintain that to replace.
Very sneaky of toyota though.
I did a search and did not find anything in this forum??
Old 11-21-2006, 02:18 PM   #4 (permalink)
View Ninja7's Photo Gallery
I would change it every 30,000 miles. Like changing your motor oil every 3,000 miles. Better safe than sorry.
Ninja7 is offline   Reply With Quote
Old 11-21-2006, 02:26 PM   #5 (permalink)
Agreed!
auto tranny fluid change on a 92 sedan jjminch Archived Corolla threads 3 01-06-2006 03:59 AM
Radiator fluid qn for '96 Corolla *cough* Prizm Risky Archived Corolla threads 1 12-07-2005 09:09 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
tranny fluid change skoman Camry & Solara Lounge 3 05-09-2002 08:59 AM
How often should you change your tranny fluid? poorguy Camry & Solara Lounge 2 04-01-2002 03:00 PM
