91 corolla stuck thermostat? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2006, 08:24 PM   #1 (permalink)
View billsif's Photo Gallery
3rd Generation 91 corolla stuck thermostat?
i have a 1991 corolla that seems to have a problem operating at the right temperature.
when i drive around town (around 35 mph) and it's cold out (lately around 35 degrees fahrenheit) my temperature needle doesn't get farther than 1/3 of the way up the gauge from the cold mark. the heat works okay, but after it's on for a few minutes the temperature gauge starts to move in reverse, back down toward the cold mark. If I get on the highway and drive around 55 or so, the needle moves way down to cold and the heat just barely works. The problem is that my transmission shifts out of overdrive to 3rd gear, the rpms skyrocket, and the heat isnt very hot. Sometimes I have luck turning on the air conditioner to put some extra strain on the engine so I can get the needle to rise slightly above the cold mark so the transmission will upshift. Is my thermostat just stuck open or could I have another problem? Is the thermostat fairly easy to replace on a 91 corolla? Thanks.
billsif is offline   Reply With Quote
Old 11-22-2006, 08:32 PM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Cool
Since a new one only cost a couple bucks, and it's probably the problem try it, but drain some of your antifreeze first so you don't lose it.. and maybe buy some more incase you do lose some..
IMHo
retiredat44 is offline   Reply With Quote
Old 11-22-2006, 10:22 PM   #3 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
I have also seen where low fluid levels can cause such a reading. Have you checked to ensure the antifreeze/water level is full? While you are doing the thermostat check both hoses that run to and from the heater core; make sure they have good connections on them. Good Luck
diver9000 is offline   Reply With Quote
Old 11-23-2006, 12:52 PM   #4 (permalink)
View cheesep's Photo Gallery
You're describing a weak or stuck thermostat. The first thing I would do is change it. When you take it out, it may look okay but if you put it in a pot of water and bring it to a boil you'll probably see that it will open way sooner than it should.
Low fluid is not the problem. If the coolant was too low, driving on the highway or stressing the engine as you've done would cause the engine temperature (and the guage) to go up, not down because you wouldn't have enough coolant circulating through the engine to properly cool it and it would begin to overheat. On the other hand, you wouldn't have heat in the passenger compartment because there would not be enough coolant in the system to circulate through the heater core.
I would replace the thermostat, make sure the fluid levels are good, and drive on . . .
cheesep is offline   Reply With Quote
Old 11-26-2006, 07:02 PM   #5 (permalink)
well, i attempted to replace the thermostat and after removing the upper radiator hose came to the conclusion that the thermostat must be located in the engine end of the lower radiator hose. is this true? if so, does anyone know what size socket to use on the two nuts? it looks like the thermostat housing slides onto two studs and two nuts are used to hold the housing in place? should i take the battery out to get to the thermostat? please help me out. thanks.
Old 11-27-2006, 05:26 PM   #6 (permalink)
The TN Member
View punter's Photo Gallery
It's on the top hose in mine. Yours will be the same.
Take the top hose off then remove the front of the themostat housing. IIRC It's the part that the hose is clamped to.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 11-29-2006, 06:18 PM   #7 (permalink)
diver9000's Avatar
So did the thermostat get fixed or what?
Old 12-03-2006, 10:21 PM   #8 (permalink)
no, actually it still didnt get finished. i live in an apartment with little room to work and now it's freezing cold out. the car is still operating at very low temperatures. i took the upper radiator hose off and removed a housing-type piece which was way too small to house the thermostat autozone sold me. when i took the housing off i saw what appeared to be a square opening into the engine. there appears to be another housing-type piece at the engine end of the lower radiator hose, which i was unable to access because of the battery and air cleaner housing being in the way, and my lack of a 10mm socket or wrench. i believe the thermostat is in that housing piece on the transmission side of the engine and does not have anything to do with the upper radiator hose at all. if someone could please confirm this i would be very appreciative before i take my time removing the battery, air cleaner housing, and anything else in the way in this 10 degree weather. you might be right about the upper radiator hose, but from what ive seen i dont think so. thanks everyone!
Old 12-04-2006, 03:38 PM   #9 (permalink)
Exclamation
it's driving me crazy how somehting so simpl ehas anyone puzzled, there's the directions..
http://autozone.com/servlet/UiBroker...3d8016a207.jsp
sad part it you were 1 minute away from fixing it..
Old 12-05-2006, 05:53 PM   #10 (permalink)
diver9000's Avatar
Nice write up Retiredat44. I hope billsif can follow that. It doesnt get much easier. I know its cold but better to fix it in the cold than in the wet & cold.
Old 12-05-2006, 06:11 PM   #11 (permalink)
Cool
I don't mean to come down hard,, or be rude,, but geeesh,,, it's soo easy....
Old 12-06-2006, 06:38 PM   #12 (permalink)
diver9000's Avatar
Well, thats true. But if he is doing it for the first time and has no one to help him, maybe he is a bit reluctant ya know....Not all of us are blessed with a wrench in our hands. But good info for sure. I hope it is helpful to him.
Old 12-07-2006, 11:45 AM   #13 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
i changed mine yesterday, already had the coolant draied (was doing timing belt and water pump) took less than 2 minutes to change the thermostat. It's easier if you remove the battery so you can get a ratchet in their with an extension.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
Removing axles from 91 Corolla Auto davekmdmd Archived Corolla threads 14 06-21-2007 05:27 AM
91 Corolla Problems for a Newbie jovanovm Archived Corolla threads 7 04-10-2006 03:02 AM
91 Corolla DX SW- 20V 4AGE??? OmegaZZ Archived Corolla threads 2 02-19-2005 08:42 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
