clutch interchangability? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-23-2006, 12:33 AM   #1 (permalink)
View 94_Rolla_Guy's Photo Gallery
I was looking on ebay and now i donno what to believe, they all say different things, sometimes contradicting there own information like this first one its saying that the clutch will fit all 4A-GE's, 4A-FE, 7A-FE, 1ZZ-FE, 2ZZ-GE, 1NZ-FE(scion eng) ??????
Does anyone know the true interchange between all these engines, i know 4A/7A share
Like this:
__________________________________________________ __
part number is 16800 ,
CLUTCH WILL FIT THESE CARS
1994 - 1999 Toyota Celica GT, GT-S with 1.8L (7AFE, 1ZZFE)
2000 - 2003 Toyota Celica GT, GT-S with 1.8L (2ZZ-GE)
8/89 - 1992 Toyota Corolla GT-S with 1.6L (FWD only)
1993 - 1997 Toyota Corolla with 1.6L
1993 - 2003 Toyota Corolla with 1.8L (7A-FE)
6/85 - 1989 Toyota MR-2 with 1.6L (4AGE)
1999 - 2003 Toyota MR-2 Spyder with 1.8L (1ZZFE)
__________________________________________________ ______
16800 04-06 SCION XA 40% 1540 215MM N/A
16800 04-06 SCION XB 40% 1540 215MM N/A
16800 94-00 TOYOTA CELICA 1.8 40% 1540 215MM N/A
16800 00-04 TOYOTA CELICA GTS 1.8 40% 1540 215MM N/A
16800 93-97 TOYOTA COROLLA 1.8 40% 1540 215MM N/A
16800 00-04 TOYOTA MR-S SPYDER 40% 1540 215MM N/A
Description:
You are bidding on a brand NEW
ACT Clutch Kit
Will fit the below models:
91-93 Celica 1600CC(1.6L) - EXCLUDING AWD/Turbo models
93-97 Celica 1800CC
00-05 Celica GT and GTS 1800CC
6/92-03 Corolla 1600 and 1800CC
03-05 Matrix 1800CC
00-05 MR2 Spyder 1800CC
Comes with Pressure Plate, Clutch Disc, Pilot Bearing, Throw Out Bearing and alingment tool.
91-94 Celica 4afe 94-98 Celica 1.8 00-03 Celica 1.8
93-97 Corolla 1.6 2005 Corolla 1.8 XRS 00-03 MR2 Spyder
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 11-28-2006, 01:13 PM   #2 (permalink)
Gameroom cash: $134355
they are NOT correct
you need to match the clutch to the flywheel you have.... ie, if you have a 200mm flywheel then you need a 200mm clutch..... 212mm flywheel, and 212mm clutch....
they ARE interchangable between all 4a engines, but is dependant on what SIZE flywheel you have..... (for instance.... my ae92 has an early bigport 200mm flywheel and the old 200mm clutch that was in my 4afe..... but that would not fit the 212mm flywheel i had initially purchased for the swap)
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
UPDATE: Clutch problem canadianae92 Archived Corolla threads 2 10-29-2005 05:13 PM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 07:47 AM
new clutch = broken wallet eyz closd MR2 Forum 4 03-12-2005 04:16 PM
