97 geo prizm headlight adjustment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2006, 11:38 PM   #1 (permalink)
View commutercar's Photo Gallery
I'm hoping someone has done this. I spent time looking for the vertical headlight adjustment screw both physically and through the haynes manual. Both low beam and daylight lights are lower on the driver side. Any help would be great.
commutercar is offline   Reply With Quote
Old 11-24-2006, 11:40 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
its a torx bit i beleive or use a flatblad screwdriver. just turn one way or the other to raise and lower or move in and out.
Old 11-24-2006, 11:56 PM   #3 (permalink)
so is the location of the adjustment screw the black plastic hole towards the fender on the headlight housing, where you can see triangle teeth connected to the treaded screw? sorry if my description sounds stupid, but thats the best way i can describe it.
Old 11-25-2006, 07:30 AM   #4 (permalink)
Bitter's Avatar
yes, theres 2 tho. one adjusts height and the other aims side to side. the inner adjustments (towards the center of the car) move the height and the outer (towards the tires) aim side to side. you'll want the drivers headlight straight ahead and a little lower than the passenger side which can be a little higher ans sweep light to the passenger side to illuminate things to the side of the road.
97 tercel headlight adjustment nbaptist Tercel, Paseo, Starlet, and Sera Forum 3 03-19-2012 07:17 AM
97 Geo Prizm 1.6 Problem ben_g99 Archived Corolla threads 4 08-09-2005 11:10 AM
'97 Geo Prizm same engine as a '97 Corolla? jbattenhouse Archived Corolla threads 5 12-07-2004 11:50 AM
97 geo prizm s10fanatic Archived Corolla threads 2 01-31-2003 01:45 PM
Geo Prizm or Toyota Corolla Talisman Archived Corolla threads 0 09-24-2002 12:09 PM
