I have a stripped lug bolt, how - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2006, 12:41 AM   #1 (permalink)
View modestobulldog's Photo Gallery
do I replace? I will be needing front brakes soon, should I do at the same time?
modestobulldog is offline   Reply With Quote
Old 11-25-2006, 09:18 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
they're pressed into the hub, so you'll have to remove it.
Old 11-25-2006, 01:34 PM   #3 (permalink)
Papa Bear's Avatar
View Papa Bear's Photo Gallery
How did you strip a lug bolt ??
Papa Bear is offline   Reply With Quote
Old 11-25-2006, 01:55 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
its easy, torque the wheel bolt too tight.
Old 11-25-2006, 05:26 PM   #5 (permalink)
View Trekie2's Photo Gallery
Ya know, I just don't get this...and I have seen this numerous times...they are just little wheels on a light car....70-80lbs\ft...that's all that is required. Man people think there wheels are gonna come off and torque the crap outta them...they should just weld them on....
Trekie2 is offline   Reply With Quote
Old 11-25-2006, 06:01 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
I've seen that shit too
Old 11-25-2006, 06:18 PM   #7 (permalink)
I think it is the tire shop at Costco, second car this has happened to (other 97 Prizm)
Old 11-25-2006, 06:21 PM   #8 (permalink)
View micro214_kp61's Photo Gallery
after you take the hub, put the old nut into the stripped bolt and pound that with a hammer.
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 11-25-2006, 06:32 PM   #9 (permalink)
Cool I just found the answer
Haynes manual 10-22. Looks pretty easy.
Old 11-25-2006, 06:49 PM   #10 (permalink)
View toyomoho's Photo Gallery
Ask them to please use a torque wrench or state they will be fixing it for free!
Old 11-28-2006, 01:07 PM   #11 (permalink)
Gameroom cash: $134355
i've set my lugs (mr2 triangles on my ae92... same hub sizes) to 78ft/lbs using a torque wrench and have had them come loose while driving.....
i go as tights as i can with the stock bar.....
Old 11-28-2006, 01:25 PM   #12 (permalink)
View dgoodhue's Photo Gallery
If they are aluminum wheels they are suposed to be retorqued. I put mine on at 100 ft-lbs with a torque wrench, and I have never had a wheel loosen up on me sicne I started using a torque wrench. I didn't look up the torque spec for the Prizm, every other car I have had, has been 100ft-lbs.
Dave
02 Highlander
dgoodhue is offline   Reply With Quote
Old 11-28-2006, 02:06 PM   #13 (permalink)
View rice's Photo Gallery
i also torque mine at 100 lbs with a torque wrench
rice is offline   Reply With Quote
Old 11-28-2006, 04:14 PM   #14 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
I do the same as well.
diver9000 is offline   Reply With Quote
Old 11-28-2006, 04:15 PM   #15 (permalink)
diver9000's Avatar
Then I think that the tire shop at Cosco should be paying for your repairs.....
89 mr2 lug bolt pattern? thePUNISHER MR2 Forum 2 10-25-2006 05:04 PM
stripped distributer bolt ozzyman778 89-95 Toyota Pickup/Hilux 6 05-15-2006 07:19 AM
Stripped Torx T-30 bolt heads -- any fix? whodaguy General Discussion 3 03-20-2006 01:11 AM
Stripped transmission pan bolt. jefe Camry & Solara Lounge 6 11-14-2004 04:35 PM
Stripped bolt SuKnSin Camry & Solara Lounge 1 05-13-2003 06:11 PM
