Rear brake adjustment - 99 Corolla CE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2006, 11:28 PM   #1 (permalink)
View modestobulldog's Photo Gallery
I was studying my Haynes manual in anticipation of replacing my rear brakes. I could not find out how to adjust the rear brakes when done. It did mention that they are self adjusting via the parking brake. How do I take up the slack when done?
modestobulldog is offline   Reply With Quote
Old 11-26-2006, 11:35 PM   #2 (permalink)
View thrustangle's Photo Gallery
Rotate the starwheel until the drum has a considerable drag to it when spun by hand. On some models, you'll have a plugged hole on the face of the drum that you can fit a brake spoon or flathead screwdriver through to adjust the starwheel with the drum on. I just rotate the starwheel until the drum fits snugly and takes some monir effort to turn by hand. But don't go too far!
thrustangle is offline   Reply With Quote
Old 11-28-2006, 10:28 PM   #3 (permalink)
Awesome Angle, thanks for your help!
Old 11-28-2006, 10:30 PM   #4 (permalink)
Is this how the brakes are adjusted on an ongoing basis? If so, I guess I should set the brake every time I park.
Old 11-29-2006, 06:09 PM   #5 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
You dont need to set the parking brake everytime. The E brake is used for convenience when you only need minor adjustments on the rear brakes. If you want to use your E brake everytime you park it wont hurt anything but it isnt necessary.
diver9000 is offline   Reply With Quote
93-97 corolla rear brake upgrade 94_Rolla_Guy Celica Forum 3 02-21-2010 01:15 PM
New TSB - Rear Brake Squeak njerald 5th & 6th Generation (2002-2006 & 2007-2011) 10 11-10-2006 05:41 PM
99 corolla electrical problem? russellcframe Archived Corolla threads 1 07-07-2006 09:44 AM
rear brake disk setup from an 87 corolla fwd onto an ae101.....possible? lifeisviewtiful Archived Corolla threads 1 09-19-2005 03:47 PM
big difference between rear drum and front/rear disc brake kthan Camry & Solara Lounge 12 09-04-2005 09:55 AM
