swaybar bushing question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2006, 07:46 AM   #1 (permalink)
View newbie212's Photo Gallery
So I'm getting this noise when I go over bumps... A rattling noise... Sounds like my swaybar bushings... I looked under the car and all the bushings seem to be fine...Can they look fine from the outside but be bad inside? I dont think it is my struts because the car doesnt bounce... It could possibly be the mounts but I'm thinking its the bushings... Are they easy to replace? Thanks in advance?
newbie212 is offline   Reply With Quote
Old 11-29-2006, 08:20 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Most likely its something else than the bushings, swaybar bushings dont sound like they rattle when you hit bumps.
Old 11-29-2006, 11:46 AM   #3 (permalink)
View wiccanferret's Photo Gallery
Easiest way to check your mounts is to pop the hood, put your hand on the mount from under the hood, and then get someone to push the bumper down repeatedly and hard enough to get a good bouncing motion.
If the mount is busted you'll feel a kind of tapping coming from inside. My money is on one of the mounts...
Edit: If bushings look fine, they are. The ones with fluid will leak for a long time before you notice any noise and the ones that are just rubber have to damn near fall off before you notice any difference.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
2007 Camry Sound System Question mw817 5th & 6th Generation (2002-2006 & 2007-2011) 36 12-27-2006 07:33 AM
Experience with polyurethane swaybar bushings? Mike Gerber Camry & Solara Lounge 6 03-17-2006 02:51 PM
Question about AE92 swaybar endlinks mhiscott Archived Corolla threads 7 01-18-2006 10:41 PM
general transmission question, 2nd, 4th and reverse do not engage!! afyouthbrigade Camry & Solara Lounge 1 09-29-2005 06:58 PM
Lower Control Arm bushing.... mega87 Camry & Solara Lounge 2 08-01-2005 08:43 AM
